Old 10-25-2022, 09:41 AM   #3
Neinris
It's easy even with just one jack stand. I've done it one at a time in the past. Once the corner is on a stand, I would remove the jack and use it to lift up the lower control arm to square off the sway bar link, for ease of removal.
Since you have four jack stands, as long as you're on level ground, why not just put the car on all four? Remember to loosen the lug nuts first before you lift that corner. Then you can have someone help you remove things at the same time.
The top spring compression nut is the nut that holds the top spring perch. Make sure your spring is being held by a spring compressor before you remove that nut. You'll see it once you remove the top nut that, which is for the strut mount.
For ease of installation, I removed the whole plastic and metal panels where the windshield wiper motor is housed. They're not hard to remove, just be careful to not break any plastic tabs, and not to scratch your paint with the metal panel.
Tags
lowering springs, rear sway bar, shocks, struts
Tokico Blue Struts and XD Shocks rexseesyou Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 03-18-2014 06:46 PM
Stock OEM front struts, aftermarket rear shocks? rexseesyou Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 02-25-2014 12:16 PM
Pros and cons of only upgrading to stiffer rear shocks? YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 02-04-2010 11:31 PM
Need to get struts for front and rear alan1828 Canada 0 09-01-2009 01:09 PM
WTB: Stock front and rear struts heeroyuy01195 Willing to Buy by private party 4 06-15-2009 12:02 AM
