![]() Drives: yaris Join Date: Nov 2018
Lets see those Warm air intakes
Winter is coming, just finished putting my warm air intake, post your setups here!
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
i assume youre being sarcastic about the warm air intake for winter?
Haha, no I am not, they do work. That's how I keep my yaris at 45mpg+ in winter otherwise it goes well below the 40s and takes forever to warm up.
https://yarisworld.com/forums/showthread.php?t=59283
Here's my set up from a few years ago. I think it works pretty well, I see intake temps between 75-90*F. I wouldn't be afraid to drive my Yaris on a hot summer day with those temps so why not in the winter. |
#5 | |
I'm surprised they don't make warm air intakes from the factory, with computer controlled solenoids they would open and close quickly.
The first or second gen prius has the airbox right next to the hot coolant reservoir, that is the closest attempt I've seen other than modern cars getting shutter flaps in the grills to restrict air flow on warm up.
This is my extreme temperature grill cover when the temps go below -30
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
Instead of doing a warm air intake, do a grille/rad block off. That way, the engine stays warm as well, and the intake always gets warm air with a hot engine.
ltwargssf
Nice setup! How much improvement have you noticed in fuel efficiency with your warm air intake during winter conditions? ex-x-fire Do you experience any drawbacks or challenges with your warm air intake setup during the winter months? IndestructibleYaris Could you share more details about your grille/rad block off setup, and how it impacts the engine's performance and efficiency in cold weather? |
Only drawback is the engine seems a little sluggish. That tells me it's getting plenty of warm air.
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 11:07 PM |
