#7 | |||
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
Misalignment of a pulley? There's no way to misalign a pulley. Every single pulley is a critical engine part that is made to tight tolerance. Defective bearings in the tensioner? You mean alternator? One of the accessories? You mean either the W.P., Alt., or AC compressor? It's not the water pump. The pulley drives a shaft which drives an impeller. Not only would you hear the impeller or shaft scraping, but the car would've leaked every drop of coolant before it'd shred a belt from the W.P. bearings being worn out. Every bit of clearance in the bearing is seen by the seals and impeller as well as the pulley. Quote:
One of my earlier repairs in my life was rebuilding the alternator around 340k miles and I had to get very familiar with the belt and alternator, and never did I think this job was ever a challenge or a mystery in any way |
| Brand new belt is squeeling | RMcG | DIY / Maintenance / Service | 17 | 06-25-2018 01:37 PM |
| DIY how to change you belt in 10 minutes without breaking VVTI solenoid | YarisSedan | DIY / Maintenance / Service | 2 | 04-12-2013 10:41 AM |
| Drive belt squeal at idle. | junorico24 | DIY / Maintenance / Service | 22 | 03-29-2013 09:27 PM |
| Altenator Belt Broken After Replaced by Toyota | Yaris_guy | DIY / Maintenance / Service | 12 | 01-18-2011 09:14 PM |
