![]() Drives: '13 Yaris LE Join Date: Jan 2016
I just purchased a used 2013 Yaris Hatchback LE.
I wanted to install an engine block heater and after doing some some reading a found out that new Toyota engines have a molded socket on the engine block specifically for a tube type engine heater. The only problem is I can find the damn hole! Even the guy at the Toyota dealership said he'd never heard of that and recommended getting an oil dipstick type heater. It probably doesn't help that I live in North Alabama where engine heaters aren't common. Has anyone installed one that can direct me where to find the socket to install my heater? |
It's on the firewall side of the engine block on the drivers side. I found it helpful to remove the battery. It's down pretty low.
Keep trying! Livin in Bama an you need a bhp
Should be this one:
Just Google "block heater install yaris world" there was a thread about it w/ pics.
It's not hard to do but if you have a m/t you'll need to remove the shift bracket and cables to access the hole. For an a/t you don't need to move anything. Cory's pics is correct. Keep in mins the hole access is on the drivers side of the engine right at the back
After more searching referencing the posted pictures I finally found the socket and installed my heater!
I never would have found it without removing the battery. I wasn't able to find any posts with pictures so I'm posting mine to help out others. The small orange piece of rubber is the electrical plug to the heater. ![]() Sent from my iPhone using Tapatalk |
Drives: Yaris 2014 LE Join Date: Dec 2025
Manuel or automatic?
Hey @Meeksworth,
Was it a manuel or automatic transmission? I have a toyota yaris 2014 and trying to figure out where the socket is! Thanks! |
| Tags |
| engine heater, heater, help! |
| FS: Block Heater | Bluevitz-rs | Items for Sale by private party | 2 | 08-23-2015 11:12 AM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| 1kr-fe engine wiring | boothybunch | DIY / Maintenance / Service | 0 | 03-28-2011 04:59 AM |
| Engine noise and Oil Lamp on | bieniman | DIY / Maintenance / Service | 21 | 12-13-2010 12:47 AM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 08:11 PM |
