Old 08-03-2026, 10:20 AM   #1
frogkings
Drives: 2009 Toyota Yaris Hatchback 2D
Wink 2012 sedan seats >> 2009 2D hatch?
Just got a 2009 base 2D hatch as I will have to junk my 2012 base sedan due to egregious frame rot.
Just did 500 miles on the '09 hatch and my back is fucked. Not a problem I had in the '12 sedan.
Can I swap the driver seats between the sedan and hatch?
Considerations:
- not sure compatibility of the two airbag systems both year and type of car (both have the older rounded face)
- '09 hatch has a record of being serviced for airbag recall
- not sure the '12 sedan was
- '12 sedan has airbag light on (think this is from a battery swap)
- '12 sedan seats have a lever that moves them up and down
Saw the thread from 2025 on the same topic, but unless I'm misreading something it seems inconclusive.
frogkings is offline   Reply With Quote
Old 08-04-2026, 03:09 PM   #2
One consideration you didn't put forward is the ability for the seat to tilt enough to allow access to the rear. Sedan seats only tilt to vertical making access largely impossible. The good news is they are a direct swap as far as bolting in. Not sure about airbag compatibility concerns.
Old 08-13-2026, 04:36 PM   #3
frogkings
Yeah this and a stripped bolt is what ended up stopping me. All the connectors looked the same though underneath.
For anyone trying this you'll need an e-torx 10 socket. Try getting all your bolts cracked before getting too far.
2009, 2012, ergonomics, mk2, seat
Rented a 2011 sedan then bought a 07 Hatch Alan1962 New YARIS Purchase Forum 6 03-04-2014 12:30 AM
2012 Fleet Sedan - Add keyless or cruise? gtrail DIY / Maintenance / Service 3 02-16-2014 12:03 AM
First Drive: 2012 Ford Focus Kal-El Off-topic / Other Cars / Everything else Discussions 18 02-25-2011 05:41 PM
Yaris Sedan Vs. Yaris 4dr. hatch Meow General Yaris / Vitz Discussion 11 10-29-2006 02:11 PM
