![]() ![]() ![]() ![]() Drives: Sc'd Yaris Sedan. Join Date: May 2007
Hooray! :) Pass side sounds good.
And I'm in south central PA so I doubt you want to go that far out of your way, less your an alcoholic. In which case drinks are still up. Edit: I assume it would be the same specs for sedans and LBs? Same hood right? |
| under hood insulation | hhcchen | Cosmetic Modifications (Exterior/Interior) | 54 | 01-28-2009 08:55 PM |
| Need Someone to Test Fit VIS CF Hood | BLAZETIGER | Cosmetic Modifications (Exterior/Interior) | 22 | 04-27-2007 08:56 AM |
| Hood gasket | acrbill | General Yaris / Vitz Discussion | 0 | 01-05-2007 09:03 PM |
| Before you buy . . . check that hood! | woof | General Yaris / Vitz Discussion | 4 | 12-02-2006 06:14 PM |
| HELP! paint dings in the hood... | oktaren | Cosmetic Modifications (Exterior/Interior) | 23 | 08-01-2006 10:20 AM |
