Old 09-14-2009, 04:35 PM   #19
kngrsll
Apexing Egg!!
kngrsll's Avatar
it would be nice to put in some Lexan while you are at it too.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 09-14-2009, 05:40 PM   #20
sex
sex's Avatar
Drives: 09 5DR
I had an 1st gen nissan quest similar to the pic attached. The side windows had a nice slim hinge and the rear had power. Removing the middle windows were easy: pop the trim and unfasten 4 bolts.
Old 09-14-2009, 05:53 PM   #21
You could use a seal simular to the kind garm sells for sealing the hood around the window. That way keeps it air tight and water tight when its not poped out and just remove the glue. And install a hindge. If you look at the mid 90s ford escort hatchbacks. Its simular size and style pop up window. Maybe can remove the hinge from one in a junk yard and try it out. Only thing is how do you go about drilling a hole in the glass window to insert it without cracking it.
For drilling the window, you use a diamond drill bit or bring it to a glass shop.
If someone is serious about experimenting with this they can have the left side window (that I posted the picture of above) just for the cost of shipping. I expected to break the window removing it, and was very surprised when I did not. I was going to throw it away, but then figured I'd hang onto it in case someone without glass coverage needed it.
Old 09-14-2009, 06:38 PM   #22
jclo3313
jclo3313's Avatar
Below are pics of the window and the frame. The glue is unbelievable. This window was harder to cut out than the windshield was. The tool I purchased has an L shaped blade that you insert into the glue and you pull it along. It was extremely hard cutting the wide band of glue with it. After I struggled with removing it I did some research and found that a piece of piano wire is far more effective. I used the piano wire on the windshield and it cut the glue far better.
Attachment 28107
Attachment 28108
Thanks for proving me wrong on that one.
Obama Can't Gymkhana!
Old 09-14-2009, 10:26 PM   #23
puetato89
Just call me Ray, better?
puetato89's Avatar
Drives: 08 Yaris
wel if scott wants 2 send it 2 me(fo fwee) i guess i can try it in his rear window
Old 09-14-2009, 10:27 PM   #24
puetato89
puetato89's Avatar
Drives: 08 Yaris
how much would shipping be??
Old 09-14-2009, 10:49 PM   #25
Looks like $15 to Orlando.
Old 09-14-2009, 10:51 PM   #26
puetato89
puetato89's Avatar
Drives: 08 Yaris
lol ok, as son as i buy my front lip and an EQ that im trying 2 find ill defenitly send you the money( most likely next week!!)
Old 09-14-2009, 11:03 PM   #27
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
if i felt like removing my window to play with this i would.. certainly seems like a viable project
Old 09-29-2009, 06:23 PM   #28
Vitz RangaaaH
Vitz RangaaaH's Avatar
I like this idea.
Vitz RangaaaH is offline   Reply With Quote
Will local bay area members please stand up! YarisSedan California 264 07-28-2009 11:53 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
rear corner windows fogging wushumasterku General Yaris / Vitz Discussion 14 01-23-2006 03:09 PM
