Old 04-10-2014, 11:55 PM   #1
Originally Posted by robkay View Post
OK, I'm not sure I did it right, but I managed to get the connectors off to inspect them without damaging them. I'm still a little confused, though.
I have a service manual on CD, so I found instructions on page AH-14 -- "AXLE – REAR AXLE HUB AND BEARING" and there it provides the instructions:
DISCONNECT SKID CONTROL SENSOR WIRE (w/ABS)
(a) Using a screwdriver, remove the claw of the connector lock portion and disconnect the skid control sensor wire connector.
NOTICE: Do not remove the connector cover from the connector because the skid control sensor wire may be damaged.
Attachment 53232
I could not remove any "claw" to remove; in fact I don't think there even is one. What I did is I followed CTScott's instruction (I think...) to remove that clip that you can raise up on top of the sensor with a screwdriver. Well, turns out it is sort of a clamshell like cover that surrounds the whole connector. You can see that there is a slotted locking clip that snaps onto a little nub; actually there is one on top and on the bottom. To get the cover off you have to raise both clips and work the thing off.
Attachment 53231
With the cover off I took a screwdriver and gingerly worked the connector off. It did finally kind of snap off. I did not find any broken pins or anything.
Is that what I was supposed to do, CTScott? When concerns me is that the manual says "Do not remove the connector cover." Well, if by "connector cover" they mean that clamshell thing that surrounds the connector, that ship done sailed. I did not damage the wires, though, and managed to get it back on OK after replaced the connector.
When I had the connector off I checked it for that "claw" they said to remove. I did not find any separate part that I could have removed. That's what confuses me about this whole thing.
They show to release the connector while it is inside of the cover. That may be possible to do if you can get into just the right position, but I find it much easier to remove the cover. As long as you are careful with the cover removal you will not hurt the wire.
Old 04-11-2014, 12:04 AM   #2
robkay
Drives: Hatch
So, is that thing they show to pry up in their picture actually a separate piece that you "remove" as they say, or do they mean to just pry it up to release it from a tooth or something? They give you the impression that there is like a clip that you actually pry out and remove. As I said, I looked at the connector carefully and it seemed like it was all one piece to me.
In any case, as you say, it would be pretty tough to get in a position to pry that thing up and pry the connector off at the same time. I agree, it's easier to remove that cover. The wires look delicate, but if you're careful and find any broken I would bet they were already corroded off.
OK, thanks for all your input! (Old subject I know...)
After doing the rear I find that my BRAKE and ABS lights are still on, so I guess I need to check the front now.
robkay is offline   Reply With Quote
Old 04-11-2014, 06:46 AM   #3
So, is that thing they show to pry up in their picture actually a separate piece that you "remove" as they say, or do they mean to just pry it up to release it from a tooth or something? They give you the impression that there is like a clip that you actually pry out and remove. As I said, I looked at the connector carefully and it seemed like it was all once piece to me.
Using this procedure you can find out which one is actually causing the error:
http://www.yarisworld.com/forums/sho...&postcount=262
Old 04-15-2014, 10:17 PM   #4
limochong
limochong's Avatar
Drives: 2007 yaris sedan
Can anyone quote me roughly how much does it cost for parts total to replace both rear skid sensors and 2 sensor wires??
Im in canada but U.S. Prices okay just want to see how much... Thanks
limochong is offline   Reply With Quote
Old 04-15-2014, 10:23 PM   #5
"G"
Drives: 2007 Yaris Hatch
You can't replace just the sensors. Only the wires.
"G" is offline   Reply With Quote
Old 04-15-2014, 10:30 PM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Sensor is I'm the hub unfortunately ull need to replace hub bearing to fix sensor and harness
Sent from my XT1032 using Tapatalk
Old 04-15-2014, 10:44 PM   #7
"G"
The hub bearing replacement only fixes the sensor, not the harness.
Old 04-16-2014, 12:50 AM   #8
limochong
limochong's Avatar
Yup~ i need to replace both hubs and both wire harnesses.
Can anyone provide me with the costs for parts ?? Thanks
Old 04-16-2014, 09:16 PM   #9
"G"
No, we are not dealers.
Old 04-16-2014, 12:59 AM   #10
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Before selling my Yaris I quoted buying all the necessary parts to fix the ABS / BREAK light issue and the cheapest I could get it was for around $250 but getting some genuine Toyota parts it goes up to around $500
Good luck
D.
CLA 250, 4MATIC
Old 04-16-2014, 07:48 AM   #11
limochong
limochong's Avatar
Thanks a lot!
Old 05-18-2014, 03:24 PM   #12
craigq
Drives: '07 Yaris, '12 GLI
Well last cleaned in Nov-2010, the ABS and ((!)) light are on again. Cleaned the connections and the lights are not going out this time.
craigq is offline   Reply With Quote
Old 05-18-2014, 03:27 PM   #13
Connections are probably broken now. You'd have to check with small cheap sowing needles and a DVOM. Digital volt and ohm meter.
Sent from my iPod Touch
Old 05-19-2014, 11:22 AM   #14
craigq
Yeah, that'll likely be the next step in the troubleshooting process Hopefully it's the rear harnesses and not the sensors pressed into the hubs...
Old 05-19-2014, 11:55 AM   #15
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
if u can scan it ...if it shows both sides , take car for spin after code erased when code comes back see if both or just one ..this will eliminate the good one or one that can wait...main problem is that when u get the light ..code.. u have to replace both ( hub ,harness ) cos its the sensor that is 99% gone :( and that will involve a new hub...sorry.
Old 05-18-2014, 03:28 PM   #16
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Yup that is about right ...had a Yaris in with same problem Saturday will need new hub and harness price around 300$
Old 05-18-2014, 03:34 PM   #17
auxmike
auxmike's Avatar
That's a darn Shame. When I bought my 08 new I couldn't find one with the abs or the side airbags either. Now I'm glad I don't have it. Abs is pretty useless anyways..
Old 06-07-2014, 06:06 PM   #18
craigq
Replaced the rear passenger side harness (the rubber boot looked terrible, broken up etc.), that didn't clear it. Disconnected the battery cable, not sure if that's required or not as I can't recall what I did the last time, still didn't help. I then replaced the rear hub w/ABS sensor, disconnected negative battery cable, and that cleared it. Wonder when the driver-side will go
Don't have a slide hammer so I improvised a pulley-puller by using two 5" bolts and nuts/washers and some spacers to remove the old hub, surprised it worked
