#1 |
![]() ![]() Drives: Toyota Yaris Join Date: Feb 2009
computer problem
I had my dell Desktop sitting collecting dust for a while and took out the hard drive and put it in an usb external exclosure and noticed that some of my files werent showing up on my Rig. The hard drive properties showed that it was using 60 gigs of data and inside the hard drive folder there was only 20 gigs. So that leads to wheres my 40 gigs? Unusual. Help!
![]() ![]() ![]() Drives: Blazing Blue Liftback Join Date: Oct 2008
#3 | |
#4 |
Beast
or if you dont care much for what those 40 gigs could be just reformat it>?
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
#5 |
super duper M*******TOR
Drives: 2007 jahPANIS egg(Sarao Phil) Join Date: Oct 2008
u might be doing something wrong...the second image is just a folder's properties not the j: drive properties that is why u r only getting 20 gb of files!
is the second image the main folder to the j: drive? |
#6 |
![]() ![]() ![]() ![]() ![]() Drives: '08 LB MT Bayou Join Date: Oct 2008
Start -> Control Panel -> Administrative Tools -> Computer Management. Expand Storage in left pane select Disk Management. Check to see if the drive is partitioned.
#7 |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
Hopefully a silly question, but.... Is the USB encloseure size-limited? Some of the cheaper ones are "old tech" that may not be able to recognize a drive bigger than 20Gb
#8 |
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
Most likely to be hidden files and folders.
#9 |
Drives: lil red 5-door Join Date: Sep 2006
40 gigs of porn!
Seriously, here's a good program you can try to use to see what's in there: windirstat.info
The price of freedom of religion, or of speech, or of the press, is that we must put up with a good deal of rubbish. - Robert Jackson ![]() Bye bye 1NZ... |
#10 |
toyota
Drives: 2007 Yaris RS Blazed Join Date: Oct 2006
get service pack 2 for windows...from what i ran into service pack 1 limit reading the whole hd.
#11 |
sp1 is limited to 128gb.
old usb enclosure MIGHT be limited to 160gb. but if the partition was created before, then it will have no problems accessing it. |
| steering problem | redgreen | DIY / Maintenance / Service | 31 | 09-18-2015 09:20 PM |
| Service Problem | Lizardboy | DIY / Maintenance / Service | 19 | 10-06-2006 10:12 PM |
