Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Southwest
Old 04-05-2010, 03:25 PM   #1
Yariz
Drives: Yaris 3dr Hatchback
Exclamation Help in H-Town, Tx
I am in Houston.
I need a bit of help with some pretty easy body work. I also need some help if anyone knows Ford V-8s. I got a car stuck at a friends house, and I can't get the thing started. I think its the distributor but I am not 100% sure. Any help is appreciated, and I reciprocate.
Yariz is offline   Reply With Quote
Old 04-05-2010, 04:17 PM   #2
Cosmonaut
The Last Baron
Cosmonaut's Avatar
Drives: 09 Polar White HB
vehicle?
engine?
why do you think its the dizzy?
i have an 87 5.0.(owned since '02) i may be able o assist you.
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires!
| UR 19mm sway |
Cosmonaut is offline   Reply With Quote
Old 04-05-2010, 04:20 PM   #3
Yariz
Thanks for the reply, and I need a Flux too lemme know where u find it.
Well the 'stang is an 1985 5.0 GT Convertible. I am getting spark off the coil, but after that I am lost. I am totally new to EFI, I used to own the exact same engine but it was carb'ed. (10yrs ago)
Old 04-05-2010, 04:32 PM   #4
Cosmonaut
The Last Baron
Cosmonaut's Avatar
does it turn over atleast or is it just...dead, no clicks, no weak starts?
| UR 19mm sway |
Old 04-05-2010, 04:37 PM   #5
Yariz
Yeah it cranks, I can hear it turn over, just no ignition.
Old 04-05-2010, 04:42 PM   #6
Cosmonaut
The Last Baron
Cosmonaut's Avatar
i assume battery is good?
you have the spark and air only thing left is fuel, is the pump whining?
this may take awhile to figure out since our cars are 20something years old but if youre not already on MF or allfordsmustang they have a TON of knowledge.
MF
check out this site.
im not trying to "pass you off" or anything but i may disappear every now and then and i dont want you to have to keep checking this when im not replying.
| UR 19mm sway |
Old 04-05-2010, 04:50 PM   #7
Yariz
New battery and Coil.
Old 04-05-2010, 05:02 PM   #8
Cosmonaut
The Last Baron
Cosmonaut's Avatar
have you ran codes on it? if not you can do it at home.
Self test
if you pull any codes that will provide a better platform to solve the problem rather than shooting in the dark.
| UR 19mm sway |
Old 04-05-2010, 05:12 PM   #9
Yariz
No, I haven't dont have a reader, I will have to give that a try. Problem is its not at home. It is about 30min away in a parking lot. If I can get wifi out there I will try to do that. No printer :( If someone has a code reader in Houston near me, that would rock if they would let me use it.... wink.
Old 04-05-2010, 05:19 PM   #10
Cosmonaut
The Last Baron
Cosmonaut's Avatar
were there any problems leading up to it or was there any thing you worked on recently?
| UR 19mm sway |
Old 04-05-2010, 06:31 PM   #11
Yariz
No, this is a car that I got from someone, its been sitting for a little while. But it was ran about 6mo ago.
Old 04-11-2010, 01:24 PM   #12
Yariz
Oh well, I will just have it towed and work on it at home. Easier that way.
Old 04-23-2010, 05:00 PM   #13
Yariz
ADMIN PLEASE CLOSE
Red light cameras coming to my town... Goose Off-topic / Other Cars / Everything else Discussions 29 03-23-2010 04:16 AM
Video of me driving through town during sunset in Hawaii! PETERPOOP Photo-Video-Media Gallery 20 09-24-2009 08:22 PM
Just some pics around town on a lazy sunday Dbeau Photo-Video-Media Gallery 16 04-21-2009 10:24 PM
there's a new barber in town thebarber Off-topic / Other Cars / Everything else Discussions 25 03-07-2009 09:39 PM
BUENO MANANA PAL TOWN ... TRD_4_LIFE Caribbean 3 03-02-2009 08:30 PM
