Old 09-27-2012, 08:18 PM   #1
400 dollar yaris
400 dollar yaris's Avatar
Drives: 2007 Yaris sedan
performance chip
does anyone know if these chips will work or if it is just some bullshit
http://www.ebay.com/sch/Performance-...oyota&_vxp=mtr
i was looking at this one in particular
http://www.ebay.com/itm/NEW-PERFORMA...b3b373&vxp=mtr
just wondering
400 dollar yaris is offline   Reply With Quote
Old 09-27-2012, 08:45 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
No.
Old 09-27-2012, 09:50 PM   #3
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
If Toyota could make a Yaris with "Up to +5 MPG fuel savings! Up to +35 horsepower! and Up to +40 ft. lbs of torque!" don't you think they'd just sell it that way?
Guessing that magic eBay device is just two wires going into a fancy tic-tac box with a resistor in it!
Old 09-27-2012, 10:53 PM   #4
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
from what I have read, those are usually a 5 cent resistor, and a dollar case. all they do is make the signal going to the computer a different voltage so that the computer compensates and usually dumps more fuel into the engine. so sure it may make a few hp or feel like it but in actuality it wont improve fuel millage or be worth the investment.
don't waste you money or time on them. If it isn't a piggy back system or a whole ECU rebuild/reprogram it isn't real.
Old 09-27-2012, 10:56 PM   #5
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Buy it and tell us if it works.
Old 09-28-2012, 06:13 PM   #6
Astroman
Modded Moderator
Astroman's Avatar
They're crap. Also the Yaris has a learning ECU so even if it did anything, the Yaris ECU would compensate and put things back to normal. Complete and utter garbage.
Old 10-01-2012, 01:40 PM   #7
CoryM
Drives: 2009 5-door, 5-speed
If it sounds too good to be true......
In this case it's definitely a scam. There would be zero increase in performance as the car computer would adjust accordingly to get back to the air/fuel ratio it wants.
Performance Chip or Rip off??? MoeStylez Performance Modifications 28 10-02-2010 08:46 AM
performance chip!! superfly78209 Performance Modifications 134 10-31-2009 09:34 AM
performance chip?? TickleTimeTim Performance Modifications 3 04-05-2009 07:52 PM
Performance Chip njyaris General Yaris / Vitz Discussion 5 07-04-2007 12:19 PM
Performance Chip *to funny* Imagine Off-topic / Other Cars / Everything else Discussions 11 05-04-2007 01:22 PM
