Old 04-30-2013, 06:07 PM   #1
TheEggYaris
TheEggYaris's Avatar
Drives: White Yaris 3d Hatch
Turbo or supercharger?
I was wondering what would be easier to install the blitz supercharger or Zage turbo kit?
TheEggYaris is offline   Reply With Quote
Old 04-30-2013, 06:25 PM   #2
TOLMACH
Drives: soarer
My guess is blitz is like 10 times easier considering it comes with its own fuel controller and you do not have to worry about the tuning, oil lines and piping ))
Old 04-30-2013, 06:26 PM   #3
TOLMACH
Drives: soarer
I am curious whether anyone has moved from Zage to Blitz?
Old 04-30-2013, 06:46 PM   #4
^ More likely the other direction.
Installs are more or less comparable. Blitz may come with its own controller, but there is no plug 'n play option, so you are in for some wiring fun.
Old 04-30-2013, 07:25 PM   #5
TheEggYaris
Damn so 1 for turbo 1 for supercharger, that leaves me in the same spot. Im leaning to the turbo but, in your opinion which would require the least mods im on a tight budget.
Old 04-30-2013, 08:19 PM   #6
Superchargers can be installed in 1 day but count on 2. I've not seen a complete full turbo install done in a weekend.
For a blitz, there are no real mods involved. Splice into the ECU, running a wire into the cabin for fuel controller, mounting the controller somewhere and bolting on the s/c itself is pretty much it. You do have to flip the alternator upside down, and pivot the dipstick 180 degrees, but there really is nothing on the car that needs to be modded to run the kit.
Old 05-01-2013, 01:52 PM   #7
Supercharger is going to be quicker.
I ran my blitz for a week without the ecu wired up....it was gutless, but it gave me time
Old 05-01-2013, 02:29 PM   #8
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
realize though that the blitz gives you 117-135 at the wheels whereas the zage can range up to 180whp.
zage takes longer and is a lot more trouble but you get more power.
Old 05-01-2013, 02:49 PM   #9
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
My auto work experience is very limited, basically only what there is a guide available for. I was able to do the Blitz install in 2 or 3 days. That was only working about 4 hours a day max.
Old 05-01-2013, 04:35 PM   #10
jcboy
Drives: Sedan 07
less money + simplicity but lower power = SC
more money + time + complexity but higher power = TC.
if you're after speed, you can go Turbo..but then again in an economy car? i'd rather SC. if it were a civic or a corolla yes i would suggest Turbo.
Old 05-01-2013, 04:55 PM   #11
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
it is clear, for easy and some power, add S/C
For more difficult but greater rewards, add Turbo
+1 Turbo
Old 05-01-2013, 04:56 PM   #12
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Have you not seen or ridden in a turbo Yaris? Apparently not. I have actually gone head to head with a few Corollas (even boosted) and the lightweight chassis along with go-kart suspension of the Yaris handles them easily with only 6-8psi of boost. As for a Civic, there are so many options that the conversation could turn into a 5k post thread. Don't dilute the OPs original intent
The question is referencing "easier". The quick answer is obviously SC. Now other posts here have already scratched the surface on a TC install as to how it is more of everything, but it comes at a price financially, time-wise, and possible complexity.
Old 05-02-2013, 01:11 AM   #13
47_MasoN_47
Plus you might have a waste gate problem and your motor explode going down the interstate :P
Old 05-02-2013, 10:44 AM   #14
TheEggYaris
Thank you all for the input, I'm leaning towards the turbo.
Old 05-02-2013, 11:21 AM   #15
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
idk if that is correct the s/c alone is 3500 new. If you can find a used one then yes s/c would be a cheaper option
I would say s/c is less of a headache than turbo and requires less maintenance
Old 05-02-2013, 05:42 PM   #16
djhuddy2442
djhuddy2442's Avatar
Drives: 2008 toyota yaris hatchback
i was at the same dilema i am going the zage turbo kit i want the sound and the power
djhuddy2442 is offline   Reply With Quote
Old 05-03-2013, 11:22 AM   #17
TheEggYaris
Do I need to upgrade the Injectors to 1ZZ before I install the zage turbo kit or will it run with a complete stock yaris?
Old 05-03-2013, 11:02 PM   #18
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
While the initial cost seems high, but with the blitz you aren't buying anything else.
With a turbo, even a kit, you'll have to buy all sorts of various fittings and other minor things that can add up to quite a bit. And then there is tuning. The blitz tuning is pretty simple. Tuning on a turbo takes time and practice, or lots of money.
Colin Chapman disciple
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 05:49 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
California legal Supercharger or Turbo? echosqwat Performance Modifications 15 11-18-2009 01:03 PM
Supercharger or Turbo????? window_lee General Yaris / Vitz Discussion 10 05-10-2009 04:39 PM
