Old 03-06-2014, 12:08 PM   #1
kou
Drives: 08 lb
Alternator voltage output.
Having a slight issue when driving and has been happening for a long time. Between gear changes I notice my headlights dim a little then go back to how they were I also notice that my gauges that I have installed also look a little dim. This problem happens about 90% of the time after starting the car and continues the other 10% the lights are always bright and my gauge lights are bright. Battery is new voltage when car is running 13.8 when I put loads on high beams and blower motor on high voltage jumps to 14v then drops to 13.4 then back to 13.8 or a little lower.not sure if I should but a new regulator and brushes in the alternator. Any help would be appreciated.
Remote Starting xairmech DIY / Maintenance / Service 35 01-22-2020 10:10 AM
Factory HU output brad4ds In Car Entertainment + Electronics (audio / video / alarm) 4 07-29-2011 12:12 PM
Increase alternator output or adjust idle? mazilla In Car Entertainment + Electronics (audio / video / alarm) 10 05-28-2011 12:49 AM
Viper Alarm Install gwasabi In Car Entertainment + Electronics (audio / video / alarm) 28 08-11-2010 02:57 PM
Parking Light Flash Output vs Hazard Light Output sex DIY / Maintenance / Service 2 11-03-2009 08:47 PM
