Old 03-11-2014, 03:34 PM   #1
lambros
lambros's Avatar
Drives: TOYOTA YARIS S 2009
Change location of trunk lamp
I just discovered that the trunk cargo lamp has the same dimensions with the emergency door panel of rear door hook...and I just pelpaced the small door panel with the trunk lamp...this is the result...enjoy
lambros is offline   Reply With Quote
Old 03-11-2014, 03:41 PM   #2
Umm.. but that's not effectively lighting up the trunk space though...
Old 03-11-2014, 03:44 PM   #3
lambros
lambros's Avatar
If your trunk is full this lamp just not exist....for hatchback...
Old 03-11-2014, 03:56 PM   #4
That's wild that it is the same dimensions. I have been meaning for ages to add one up at the headliner, as I often find that my side one is blocked and I can't see.
Old 03-11-2014, 05:44 PM   #5
lambros
lambros's Avatar
I have still the option to plug in another lamp to the previous spot...
When I find another probably I do it...
Old 03-11-2014, 05:47 PM   #6
Revsson
That looks like a clean install, nice going!
How did you run the wires? I know that the lamp on the side is
almost useless when the back is full on the hatchback. I've thought
about trying to add some light elsewhere.
Old 03-11-2014, 05:56 PM   #7
lambros
lambros's Avatar
The wire is very easy to run with the other wires of rear wiper...when remove the door panel first of course...
Old 03-11-2014, 06:23 PM   #8
bairjo
So did you move the light or add it on for more lighting? If you had both you would have the best of both worlds...you might blow a fuse though.
Old 03-11-2014, 10:22 PM   #9
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I did the same thing a couple of years ago but with an extra bright LED panel I ordered on Ebay so I have an extra light in addition to the one on the side. I tapped into the existing lamp so they both come on together.
-Type 07 FFL-
My odometer 03/11
Old 03-11-2014, 11:18 PM   #10
bairjo
nice!...it will be on my to do list...
Old 03-12-2014, 12:19 AM   #11
lambros
lambros's Avatar
The best...
Planning first oil change @ 500 or 1000mi schleppy DIY / Maintenance / Service 39 07-09-2010 06:28 AM
LED Change for the AT Shifter for a Liftback? omendt Cosmetic Modifications (Exterior/Interior) 3 06-24-2009 10:53 PM
Trunk issue Lowfront In Car Entertainment + Electronics (audio / video / alarm) 1 09-24-2006 06:55 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 01:26 AM
