Old 03-28-2014, 03:28 PM   #1
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
ABS light, no Code
ABS light keeps coming on, I assume it has something to do with the light weight flywheel.
Old 03-28-2014, 03:33 PM   #2
Does it come on and then quickly go off, or does it say on until you kill and restart the car?
Old 03-28-2014, 03:51 PM   #3
Golddeenoh
Golddeenoh's Avatar
twice it came on right after starting and driving but went off before i left the parking garage, and another time i was in traffic and it stayed on for a little while and then went out. Fluid is full, no signs of leaks.
Old 03-28-2014, 03:53 PM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I ran into that a couple years back and it ended up being the sensors. Toyota replaced them.
Old 03-28-2014, 04:07 PM   #5
^ That would be my bet as well. I would check the connectors on the rear sensors, as they are very prone to corrosion. If you catch it early enough you can clean and seal the connectors.
Old 03-28-2014, 09:41 PM   #6
Golddeenoh
Golddeenoh's Avatar
I will have to look into that. Only 52k miles on the car, and no driving in northern salty areas.
Old 03-31-2014, 01:04 PM   #7
Golddeenoh
Golddeenoh's Avatar
VSS on the passenger's side. the bolt had backed out so the sensor would occasionally wiggle back in its hole. new bolt and torqued, problem should be solved.
OFFICIAL Yaris SEDAN thread SimmZ Photo-Video-Media Gallery 1706 06-22-2025 05:33 AM
Sponsors List RogueYaris Sponsors Classifieds Area 14 01-05-2013 10:23 PM
Brake & ABS Light On JeffRapp DIY / Maintenance / Service 3 01-04-2013 11:10 PM
Sharing and Need Help! Lowered but abs light came on! tobymak21 California 0 08-08-2012 08:48 PM
