Old 04-09-2014, 07:54 PM   #1
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
SE Steering Ratio
I know the Yaris SE has a faster steering ratio than non-SE models. Does the SE achieve this by offering a different pinion or steering rack?
Just wondering what it'd take to add the faster steering to a non SE.
Additionally, what is the ratio on the SE vs non SE?
Old 04-09-2014, 08:32 PM   #2
nookandcrannycar
I just know that I would prefer a 5-door 3rd Gen 5-speed over a 3-door 3rd Gen 5-speed, but I'm SOL on that because I'm not willing to give up the tighter turning circle of a non-SE.
Old 04-09-2014, 10:11 PM   #3
SE:
Steering Ratio - 46.17
Lock to Lock Turns - 2.3
Turning Diameter - Curb to Curb - 36.7 ft
LE:
Steering Ratio - 49.93
Lock to Lock Turns - 3.0
Turning Diameter - Curb to Curb - 30.8 ft
It is achieved with different ratios in the rack. There is a different part number for the two, so you could swap an SE into an non-SE.
Old 04-10-2014, 02:52 AM   #4
nookandcrannycar
SE:
LE:
Could the opposite be done (LE rack into an SE) ? If so, would the tires and wheels also have to be changed to LE OEM tires and wheels to achieve the same turning diameter as the LE ? Would doing the rack swap invalidate the warranty on all parts touched in order to make the swap?
Old 04-10-2014, 07:56 AM   #5
Yes - You could go the other way. I do believe that you would need the narrow tires otherwise you would probably scrape on full lock. For warranty I would expect them to give you a hard time on anything that was touched to do the install.
Old 04-10-2014, 01:44 PM   #6
nookandcrannycar
Thanks .
Old 04-10-2014, 01:31 PM   #7
Thirty-Nine
SE:
LE:
Those steering ratios can't be right. The 2015 Honda Fit steering ratio is 14.1. The Nissan Versa is 16.8. A Ford F-150 has a 20.0:1 ratio.
EDIT: It does say those ratios even on Toyota's press material, but it cannot be right. My Suzuki Sidekick has a steering ratio of 19.4:1 and I assure you its steering is MUCH slower. Plus, the previous-gen Yaris has a 19.7:1 ratio.
Old 04-10-2014, 02:30 PM   #8
Jason@SportsCar
The numbers CT posted are the degrees of steering angle at the wheel each trim level has, not the actual ratio. Toyota math.
Working it out based on number of turns and degrees of available wheel angle it should be 18.19 for the SE and 21.6 for the rest.
Old 04-10-2014, 05:59 PM   #9
Thirty-Nine
Gotcha. Thanks! That makes more sense.
Old 04-17-2014, 03:10 PM   #10
Jason@SportsCar
My math was off a bit, I think I had some part of the equation wrong.
Word from Toyota is 14.3 for the standard cars, 13.2 for the SE.
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 02:41 PM
Steering column compatibility between Euro Yaris and US Yaris Micropurchase Third Gen Yaris General Discussion 19 09-17-2012 01:00 PM
Steering wander, adjusting EPS assist Snubba Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 05-22-2012 06:39 PM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 04:54 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 11:16 AM
