Old 05-25-2014, 09:51 AM   #1
Slanoie
Drives: Yaris 09 4 doors hatch M/T
Advice : noise in suspension?
Hi guys,
As summer is coming, I did some maintenance on my Yaris and I have a strange noise on it. When I turn the steering wheel, I hear a "TOC" when I go from left to right / right to left. The same sound that I was used to with a tie rod end failure on my (two!) previous dodge neon.
Checked the tie rod end, ball joint, every suspension linkage, bushings, also the springs, everything seems fine. Went to the dealer and they told me it was the steering gear (!)...
My question : is it safe to drive with too much play in the steering gear? I don't see how it could fail, and I would like to have it repair (I'll do if it's unsafe), but it's not a cheap thing...
Slanoie is offline   Reply With Quote
Old 05-25-2014, 10:49 AM   #2
Astroman
Modded Moderator
Astroman's Avatar
Sorry can't help you but I did move your thread into the right section.
Old 05-25-2014, 04:21 PM   #3
lambros
lambros's Avatar
Drives: TOYOTA YARIS S 2009
Common problem with the steering column....
Changing my own on Monday through guarantee.
All European petrol engine MK2 Yaris (with adjustable steering column) have the same problem....
lambros is offline   Reply With Quote
Old 05-25-2014, 10:07 PM   #4
Originally Posted by Slanoie View Post
Hi guys,
The worst case failure mode is jamming, but I don't think that is a likely failure.
I have a spare and tight steering rack assembly if you are interested.
Old 05-28-2014, 05:54 PM   #5
Slanoie
Yeah, I guess I would feel it more than that before jamming, because now it's still smooth except some vibration and knocking noise at low speed.
For your spare steering rack, thanks for the info, but I'll wait to have an answer from my dealer. Still waiting...
Suspension Problem (Noise Creak) , Need Help here plz ! maranello33 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 04-02-2012 02:08 AM
Suspension advice and pic request Misterawa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 23 02-10-2011 03:26 PM
The weird, old and new. Brakes, Sqeaking, Suspension noise Lafiro DIY / Maintenance / Service 2 10-31-2010 10:20 PM
Noise from suspension... Lafiro General Yaris / Vitz Discussion 12 05-10-2010 11:26 PM
