Old 11-26-2014, 10:24 PM   #1
ucsmfu
Drives: yaris le
2012 Yaris fog lights issue
Hey guys,
i bought a set of fog lights on ebay, had them installed today, everything works well, however noticed that the fog lights were aimed really high. Points almost same height as the headlights.
Just wondering if there's anyway to fix it ? I couldn't find a adjustable knob in the back of the housing.
ucsmfu is offline   Reply With Quote
Old 11-26-2014, 10:49 PM   #2
Some of the ebay ones are truly junk. If they don't have an adjustment knob they are not adjustable.
Old 11-27-2014, 12:15 AM   #3
hondajt
hondajt's Avatar
Drives: 2013 Yaris LE 5Dr
There probably is an adjustment screw that uses a screw driver for adjustment. Have a link?
Looking for fun!
hondajt is offline   Reply With Quote
Old 11-27-2014, 07:31 AM   #4
ucsmfu
Drives: yaris le
This is the one I bought
http://www.ebay.com/itm/TOYOTA-YARIS...beae8a&vxp=mtr
Old 11-27-2014, 07:33 AM   #5
ucsmfu
Drives: yaris le
Just wondering if anyone knows if the 2010-2011 Prius fogs are the same size as the 2012 Yaris ?
Also, it looks like the OEM yaris fogs are made by Valeo ?
Anyone know where I can purchase them for cheap ?
Old 11-27-2014, 07:43 AM   #6
G-Ammo
G-Ammo's Avatar
Drives: Toyota Yaris 2009; 1.0 3 Cil.
Hmm Look for this beige/grey kinda knob on it... if they're on your car, they should be underneath the foglights, just pop a screwdriver in them and turn until they're pointed downwards on the streets.
If you can't find the adjustable knob... then I suggest you either keep them off and only put them on in deep mist, or else other people will be angry at you :)
Speedbumps suck...!
G-Ammo is offline   Reply With Quote
Old 11-27-2014, 07:45 AM   #7
The 2012 ones are the same (other than the bumper trim) as the 06-11 Yaris and a slew of other Toyotas. You can often find used ones reasonably on ebay. For aftermarket ones, the ones that Micro Image sells are good and are adjustable.
Camry 2007-2010
Corolla 2009-2010
Highlander 2008-2009
PRIUS plug-in 2010
RAV4 2006-2009
Scion xA 2005-2006
Old 11-27-2014, 07:23 PM   #8
jcboy
Drives: Sedan 07
the adjustment screw should ideally be accessible with a long screwdriver under the engine splashguard, somewhere below the fog. the owner's manual might have instructions for the exact location.
So how are you liking your 2012 & 2013 Yaris SE? The Squirrel Mafia Third Gen Yaris General Discussion 32 04-14-2014 03:30 PM
2012 yaris led rear fog lights dailygrindin Cosmetic Modifications (Exterior/Interior) 8 04-17-2012 08:10 PM
06-07 TOYOTA YARIS 4DR SEDAN OEM FOG LIGHTS FOGLIGHTS Usmc1968 Items for Sale by private party 2 03-31-2009 07:35 PM
