Old 04-29-2015, 09:41 PM   #1
YodaBird
Drives: Gray
Changing Engine Filter
I can't find any instructions on changing the Engine filter, I assume it's not that difficult, anyone can give me any insight ?
YodaBird is offline   Reply With Quote
Old 04-30-2015, 04:49 AM   #2
mrpj
Drives: 2014 Icon+ 1.33l Multidrive
If you mean the engine oil filter and it's the paper cartridge type then you might well need one of these, or similar, to remove the cover. http://www.amazon.com/Assenmacher-Sp...ols+toyota#Ask
mrpj is offline   Reply With Quote
Old 04-30-2015, 10:43 AM   #3
vrait
vrait's Avatar
I'd assume he's talking about the air filter.
https://www.youtube.com/watch?v=iss_29B5V0k
vrait is offline   Reply With Quote
Old 04-30-2015, 11:07 AM   #4
YodaBird
Drives: Gray
Correct, the air filter. It's the same in the video as in the newer Yaris ?
Old 04-30-2015, 10:00 PM   #5
YodaBird
Drives: Gray
I have the filter, I just wanted to know how to install, I know there are two latches, it's as simple as releasing those latches, that's it ?
Old 05-01-2015, 06:01 AM   #6
mrpj
So why not write engine air filter?
Old 05-01-2015, 08:21 AM   #7
bronsin
bronsin's Avatar
It is NOT easy to change the AF on my 09 hatch. The AF housing location is crowded and the very stiff intake and connecting hoses make getting the housing apart and back together again very fiddely.
You can do it but it takes time. I guess it doesnt help any that I am old and have aches and pains!
Old 05-01-2015, 09:48 AM   #8
Yes, the gen2 and the gen3 are the same. Fortunately with the gen3, thanks to the change in headlight shape, there is a bit more room to reach in and work the clips.
Old 05-01-2015, 12:31 PM   #9
YodaBird
Drives: Gray
In the video there is an electrical wiring that is disconnected, must this be done on the third generation, or no ?
Old 05-01-2015, 12:45 PM   #10
Again, the construction of the gen3 is the same as gen2. To simply replace the primary filter element, nothing needs be disconnected. He is disconnecting everything attached to the top of the air box in order to be able to flip it over and show the secondary charcoal filter to the camera.
Beware WIX Filter #51394 zkay DIY / Maintenance / Service 19 12-22-2012 01:09 AM
changing fuel filter yaris9876 DIY / Maintenance / Service 8 10-01-2011 11:03 PM
Part Number(s) for '09 5-door LB engine air filter? IsLNdbOi DIY / Maintenance / Service 5 01-02-2011 02:51 PM
Oil change without changing filter teddy DIY / Maintenance / Service 14 06-25-2009 12:50 AM
Changing engine and transmission oil poopyflux General Yaris / Vitz Discussion 4 03-09-2009 06:17 AM
