Old 07-03-2015, 08:19 AM   #1
unadilla66
Drives: '07 3d, '10 3d, '12 3d
Cup- holder removal..?
Dumb question (maybe....):
How the heck does one remove the cup-holders at each
end of the dash? Something sticky was spilled in one of
mine at some point, and it sure would be easier to clean
if the part that pivots open could be removed...
thx
unadilla66 is offline   Reply With Quote
Old 07-03-2015, 01:53 PM   #2
MedMantle
MedMantle's Avatar
Drives: Yaris '05 1.3 Hatch "R.I.P."
I would also like to know ** It was the only thing stopping me from removing my dash 'cause the front piece would just clip loose but I couldn't get it out and once I started damaging the plastic I stopped..
MedMantle is offline   Reply With Quote
Old 07-04-2015, 02:39 AM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
You can remove them by squeezing the sides however be careful as thwre are small springs that can shoot out on you. Pay close attention while you do it so that you know how to put the springs back in plac.e the springs are what control the slow opening and make the "tap" open function work.
Sent from my SCH-I545 using Tapatalk
Old 07-04-2015, 12:34 PM   #4
unadilla66
Hmm. Mine don't seem to have a slow-opening or tap open function- basically you just pull them open and push 'em closed. The sides seem to have vertical downward facing 'hooks' in the plastic at the back that catch and stop the holder from opening more than it should. Seems like those need to be 'lifed' to get over the catch, but damned if I can get them to clear (afraid something's going to snap if I put too much force into it....).
Old 07-05-2015, 10:25 AM   #5
Sedan and Liftbacks have completely different cup holder assemblies. For the liftback, the cup holder is mounted to the inside of the dash top with a screw, so you have to remove the dash top to remove them.
Old 07-05-2015, 10:37 AM   #6
nookandcrannycar
thx
Given what CTScott posted about having to remove the top of the dash to properly unscrew the holder mounting.....perhaps buy a new toothbrush...brush the inside with water or some type of cleaner....wipe with a hand wipe (the ones sold in cylinders to keep in cars).....dry with a paper towel....then throw the toothbrush, etc. away.
Old 07-05-2015, 11:43 AM   #7
unadilla66
Yeah, basically what I already did (I save old t-brushes for just such things), but
there's still some stickiness that offends my obsessive-compulsive sensibilities! I think I'll just struggle to ignore/live with it until I have another reason to take the dash to off!
Old 07-05-2015, 04:53 PM   #8
nookandcrannycar
CUP HOLDER REMOVAL? SweetRS Cosmetic Modifications (Exterior/Interior) 13 09-19-2016 08:43 AM
08 cup holder removal? Melloreel DIY / Maintenance / Service 12 05-02-2013 12:06 AM
Loose Change holder(?) and cup holder nemobile Cosmetic Modifications (Exterior/Interior) 14 02-21-2012 09:56 PM
cup holder removal DOMAV General Yaris / Vitz Discussion 9 08-27-2009 11:32 AM
