#1 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Check out my write-up on comparing my Amsoil and Mobil 1 samples, You may be surprised....I sure was.
http://www.armstrongfamilyblog.com/a...oil-vs-mobil-1 How to take the sample VIDEO: https://youtu.be/IGNzIf73AMk
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 01-14-2018 at 11:30 PM. |
![]() ![]() ![]() ![]() Drives: 2007 2-door hatchback Join Date: Jul 2016
it would be nice if test results gave viscosity at the low temperature end (10w)
#3 | |
![]() ![]() ![]() ![]() ![]() Drives: 06 2ZR Turbo Yaris RS Join Date: Aug 2017
I'd love to see how SuperTech Full Synthetic holds up but I think they only go up to a 5W30. Have you tried Rotella T6? A quick search at BITOG yeilded this: It's largely about motorcycles but maybe helpful, maybe not. https://www.bobistheoilguy.com/forum...&Number=915614
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ |
#4 | |
Data doesn't lie
Your link to the oil forum was an interesting read, and it makes me think Mobil1 and Amsoil might be using the same base stock oil. I was using 10W40 oil in an engine designed for 5W30, so I dont think the viscosity was the problem. Or maybe I do need to go to a 15W50? Who knows... |
#5 | |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
To add to this I will soon (2.5k km away) have a UOA on 0w30 Mobil 1 with 18k km on it. I will be refilling with 5w30 Penzoil ultra platinum and doing another UOA to compare.
I've ran over the idea of going with a 0w40 euro spec'd oil to add to high temps at the track. I don't think I'll be going that route since a 40 weight is a bit higher than the engine is spec'd for and it really isn't needed as my oil pressure seems fine at the track. I find it hard to believe that viscosity is an issue on your oil sample. I'm thinking it may have been lower than they expected but not a lubricating issue. Today's oils are getting darn impressive with their additives and they seem to be able to protect from sheering at crazy low viscocities. One of the reasons manufacturers are spec'ing 0w20 oils. Offers better emissions but doesn't lead to destroying rod bearings.
#7 | |
Data doesn't lie
#8 | |
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
idk if that is true, but i've steered clear of penzoil products ever since... |
#9 |
My bs meter is going off lol, I appreciate the info though. I haven't read anything on BITOG about that and the UOA's on the ultra platinum are pretty good. I'll give it a go and post up my info
#10 |
Data doesn't lie
yeah that is BS.
This is why I'm transparent and share all of my results, too many people talk too much with no data to back up their claims... |
#11 | |
![]() ![]() ![]() Drives: 2018 Yaris SE 5MT Join Date: Aug 2017
Good read, thanks guys. I've never had an oil anaylsis run, so interesting to see. I have found that at a macroscopic level the quality brand (or what I view / read are quality brands) synthetics I've used have done well; i.e. no stink, no bad discolouration or feel, even after going well beyond recommended oil change interval. So really I can only assume that they have not notably degraded and in turn provided good lubrication. Wonder how each really compares under the scope.. Especially looking forward to seeing the Pennzoil Ultra Platinum results as I just bought a bunch of it - it was on for a good deal at Canadian Tire, plus an additional $10 / 5L jug rebate from Pennzoil; thought I couldn't go wrong! ![]() -- Adam |
#12 |
like i said, idk. i've never used penzoil and i seen it was on sale one day too. i didn't want to take any chances with some kind of new oil formulation, so i just bought the royal purple, which was also on sale...
#13 | |
Data doesn't lie
Royal Purple is another oil I'd like to see results on....You should send in a sample. |
| Tags |
| blackstone labs, oil analysis |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 09:14 PM |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 08:18 PM |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 03:47 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 05:22 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
