Old 09-27-2021, 12:58 AM   #1
stiglitz
Drives: 2015 Toyota Yaris MT
How can I seal liftgate wiring to prevent water?
Installed a new liftgate/hatch for my hatchback. All the tabs of this plastic ring from the donor hatch are broken. This results in the rubber boot/wiring/plastic ring to be loose and not form an adequate seal to keep water out.
I don’t want water getting in and soaking my headliner. What should I do? I can’t replace the plastic ring with a new one; the opening of the ring is not big enough for the wiring harness connector to pass through. This is where the wiring is located, for reference: https://imgur.com/a/Z7vLU8n
Maybe use some silicone???
I am on mobile. The photo should be rotated 90 degrees clockwise.
File Type: jpg 6EE79111-7539-4916-959F-3B3F09FB180A.jpg (145.0 KB, 55 views)
stiglitz is offline   Reply With Quote
Old 09-27-2021, 12:59 AM   #2
stiglitz
@CrankyOldMan
Old 09-27-2021, 06:12 AM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Hmm. Can the lip of the grommet hold it in place? That's what should seal it. Worst case scenario, get a small tube of silicone sealer and just glue it in place?
Old 10-14-2021, 06:16 AM   #4
jasmineroylin
Drives: BMW
Seems unlikely. Cars are not airtight, there are vents and places that let air in/out, so it will fill with water rather quickly. The seals around doors, windows, etc are for keeping moderate volumes of spray, rain, etc out, not water from being submerged. That takes a whole different level of sealing.
I spent a lot of money on booze, birds and fast cars 7014 vs 7018 MIG.
jasmineroylin is offline   Reply With Quote
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
Can generic silicone be used to seal a roof channel seam against a water leak? RMcG DIY / Maintenance / Service 6 12-27-2022 12:11 AM
Water or Water/Methanol Injection DIY 06YarisRS Forced Induction Forum 41 06-20-2020 02:03 AM
Fuel pump, sender, seal, wiring, and cluster mavrick DIY / Maintenance / Service 5 07-22-2019 05:34 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
