Old 12-21-2022, 06:57 AM   #1
DSA777
Drives: Yaris Hybrid 2020
2020 Yaris Hybrid Washer fuse location?
My first post so go easy on me..
My Yaris windscreen washer has stopped working after the cold spell. I wanted to check the fuse is intact for the pump.
In the manual I can find the windscreen front and rear wiper fuse locations but not the washer pump fuse location. I'm assuming it's in the under bonnet fuse box, any help as to which one it is would be appreciated before I take it into the dealership.
I saw this pic online, hopefully it helps someone point me in the right direction.
DSA777 is offline   Reply With Quote
Old 12-21-2022, 12:02 PM   #2
thetut
Drives: 2007 4dr sedan
Was your washer tank filled with antifreeze or plain water? You may just have to park it somewhere warm for a while if it was just water.
If it was antifreeze then you should see the map of fuses on the inside of the fuse box cover.
Look for fuse marked WASHER and don't forget that there is a fuse box under the dash in the passenger compartment. This is where I would expect to find the washer fuse.
thetut is offline   Reply With Quote
2020 YARIS HATCHBACK STEERING DEFECT dhodges74 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-08-2022 07:36 AM
Ignition fuse location Strider199 DIY / Maintenance / Service 11 09-06-2012 10:11 PM
