Old 06-02-2023, 09:50 PM   #1
theinteriorautomechanic
Drives: Slowcart
Arrow Brian Crower Valve Spring Question
Hi all I'm in the process of building my Yaris currently. Currently I am going all motor. I have done the following: AEM CAI, Weapon R Header, Tooter Intake Runner Extender, 2AZ throttle body, port matched intake manifold, 1ZZ injectors, and FTG Tuning Reflashed ECU with higher redline.
My question is with the increased rpms and (hopefully) more horsepower should I consider upgrading to Brian Crower Titanium Valve Springs and Retainers or will stock springs be ok? I'm planning on doing autocross and track days with it so dependability is super important.
theinteriorautomechanic is offline   Reply With Quote
Old 06-03-2023, 01:06 AM   #2
Turbiini
Drives: 1983 carina 2NZ-FTE
i had valve float about 7000rpm na and 6800 with turbo.
Turbiini is offline   Reply With Quote
Old 06-03-2023, 05:28 AM   #3
lani100
lani100's Avatar
Drives: Yaris T sport TRD turbo
Stronger springs are a must for reliability especially at higher rpm
2004 Yaris T-Sport
1NZ-FE with TRD Turbo
lani100 is offline   Reply With Quote
Old 06-04-2023, 12:58 AM   #4
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
Pretty much a mandatory upgrade if you plan on spinning it over 7 grand.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 06-05-2023, 02:44 PM   #5
remcafee
also leave the stock crank pulley on if youre reving that high, lightened pulley will disintegrate
Old 06-08-2023, 10:39 PM   #6
Cletus Garfunkle
Average KKT User
Cletus Garfunkle's Avatar
Drives: 2001 Echo
I would only think about springs if I put a cam in the car. New springs and retainers could never hurt probably increase reliability a lil bit. I've never or don't think I've ever had problems spinning to 8k with stock springs or rods beating the sh!t outta it for 6 months. Have you thought about porting the head if you were to go through all the trouble to change springs? This is my personal opinion ofc. If you want to spend the time and money go for it learn something new in the process make it more reliable what's wrong with that!
Cletus Garfunkle is offline   Reply With Quote
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
PCV valve question window_lee DIY / Maintenance / Service 31 10-22-2014 04:05 PM
Track Suspension id3379 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 85 06-11-2009 05:59 PM
spring rates question botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 05-11-2009 12:33 PM
BailOut's Interview: Conservation in 2009 and Beyond ChinoCharles Fuel Economy Forum 43 02-24-2009 03:03 PM
