Old 04-16-2026, 08:59 PM   #1
ColinLaughton
Drives: Toyota Yaris Toyota Vellfire
Cabin heater matrix
Hi,
I'm going insane..
Never had good heat from my 2007 1.3 Yaris. I have down the following:
Replaced water pump
Replaced thermostat and checked working at temp
Back and forward flushed matrix and observed no dirt coming out, and smooth fast flow exiting matrix in both directions.
When car is at temp, some heat comes into the cabin.... But mostly from left side vents but not right. This heat is poor but there.
The matrix pipes are RED hot going in and slightly less red Hot going back to engine.
The actual matrix when checked on the side of the pipes is HOT
No signs of coolant leaks in cabin or in engine bay.
HELP!!!! 😭
MANY THANKS!
ColinLaughton is offline   Reply With Quote
cabin heat, coolant, heater, heater core, matrix
Squirrels sleeping inside Cabin Filter YodaBird Third Gen Yaris General Discussion 5 12-12-2021 11:26 AM
DIY - Cabin air filter location (Belta, Vios, Yaris sedan) Murtaza_murti DIY / Maintenance / Service 5 04-05-2012 11:03 AM
Rostra seat heater and lumbar support sesmith In Car Entertainment + Electronics (audio / video / alarm) 1 01-03-2009 08:51 AM
Install a Yaris deck into a Matrix... bad idea?? Help needed!! SimmZ In Car Entertainment + Electronics (audio / video / alarm) 4 12-17-2006 01:01 AM
