rear spacers [pics]
I got the 10mm rear spacers on today. Here's a couple before/after pics. Subtle, but it really makes a difference from some angles, especially with the kit on there.
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
greatly improved! looks balanced now
SPONSORED BY
![]() ![]() ![]() ![]() Drives: 07 Yaris LB Absolute RED Join Date: Apr 2007
is there any other advantage for spacers besides looks?
v |
Lonesome Cowboy
Ichiba sales pitch...
Wheel Spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
SPONSORED BY
![]() ![]() ![]() ![]() ![]() Drives: 2007 Bayou Blue!!!!!!! Join Date: Nov 2006
I like it Cali!!
Hey cali yaris,
Looks very good! If I recall, you were running 16x7's, ET38 with 195/50/'s. So now, you're essentially running FR, ET38; and RR, ET28. Is that right? Did you use hubcentric spacers with longer bolts? Are you flush all 'round now? |
#7 | |
Probably flush up front (but very tight...good he went with the 195's). Like you, I'm curious where that rear rubber sits now... looks about flush in the photos. |
#8 | |
Lonesome Cowboy
yes, he is but someone suggested he go with another 10 which would be 20 total, I already edited my comment because I didn't want to enter into a discussion over it, right he only used rear spacers, there is no need to touch the front I'm considering going with 15mm spacers now in the rears
SPONSORED BY
Hi!
if you overkill with spacers, you might need extended lug nuts depending on your wheels, just fyi. but looks good with the 10mm!
Hi!
I know right?
brick, did they come with extended studs? No way I'd run 10mm with the stock ones.
-Kev 07 Bayou Blue Liftback 5-spd manual |
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
6 threads on the stud is all you need to safely install your wheel
#13 | |
I know right?
When your wheel flies off at 65 mph, you'll be wishing you didn't skimp and got the longer studs to begin with...if you live, anyway. Why skimp on something cheap and easy to install that provides extra safety?
#14 |
*Fluuuuush!*
#15 |
![]() ![]() Drives: 07 yaris Join Date: Dec 2006
i wonder if the hub spacers from an XB will work with the camber shims.
cali- is that what you used for a spacer or just a wheel spacer
'07 blazing blue hatch-TRD shocks-tanabae df210-TRD rear sway bar-koning feathers 16x7-the basics for now |
#16 | |
Lonesome Cowboy
Ichiba makes spacers for the yaris also both kits come with longer bolts, I asked him if he used the longer studs or if he was able to get by with the stock ones but I didn't get an answer
SPONSORED BY
#17 |
![]() ![]() ![]() Drives: '07 Blazing Blue LB, '09 Jetta Join Date: May 2007
Hey Cali..
i thought you were gonna show up at the meet today??... man, i was hoping to meet you. well..anyway, i just got back from the meet..it was very cool.
current: '07 Yaris LB - '09 VW Jetta ex: '06 Beetle S(19x8.5 Audi A8) - MK4 GLi BMP(18x8 OZ, K04) - '03 GTi(17x7.5 Ronal, APR93) - '01 GLS - '88 GTi - '86 GTi - '83 GTi Last edited by seanele; 08-11-2007 at 04:42 AM. |
#18 |
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
im waiting to hear if he used longer studs as well.....
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
| Rear VITZ Emblem & Hatch Opener Painted Polar White. [pics] | Chris07LB | Cosmetic Modifications (Exterior/Interior) | 39 | 05-04-2007 05:20 PM |
| rear fog light and tuned rear lights | lefti696 | Cosmetic Modifications (Exterior/Interior) | 0 | 11-09-2006 03:06 PM |
