Old 01-06-2019, 04:13 PM   #1
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Smile Transmission upgrades and retrofitts
Take a look at how the C transmission progressed from 180 until now!https://youtu.be/NcoWBQTAurM
ArmstrongRacing is offline   Reply With Quote
Old 01-07-2019, 11:45 AM   #2
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
This guy makes me wanna rip apart trannys lol
myfirstyota is offline   Reply With Quote
Old 01-07-2019, 01:13 PM   #3
tmontague
tmontague's Avatar
I'll be watching the video later this week, always look forward to the trans builds
Old 01-07-2019, 11:54 PM   #4
ArmstrongRacing
Data doesn't lie
Well that’s quite the risky statement
Old 01-08-2019, 06:36 AM   #5
myfirstyota
Depending on how one interprets that statement...yes lol
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
Old 01-08-2019, 02:54 PM   #6
Leegamer
Leegamer's Avatar
This is really cool. I would love to acquire some junk trannies just to take apart and learn to put back together and then eventually mod transmissions for my own cars.
I'm a hermit named Lee
Old 01-09-2019, 08:55 AM   #7
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
This is what I did about 5 years ago. It started with lots of research into part numbers to look for compatible gears, then turned into buying four different C-series gearboxes on the cheap and completely stripping them down. There are a few specialty tools that will make it easier, but you don't have to get all of the Toyota Special Service Tools (SSTs) to get it done. If you plan on changing any individual ratios you will need access to a hydraulic press (20T or bigger), bearing separators and some misc gear pulling tools. I'd plan on investing at least $500 into tools if you want to do it right, less if you're OK with breaking teeth off the gears. =)
Old 01-09-2019, 09:03 AM   #8
Leegamer
Leegamer's Avatar
Awesome, thanks for the insight! I'm about to buy a new house with a massive garage and will build up my tool collection over the next few years as I start to undertake various automotive projects that have been on hold due to my lack of garage.
Old 01-09-2019, 09:47 AM   #9
CrankyOldMan
From 1980? =)
You should also update the 3-4 shift arm. The one in the C50 I'm (slowly) rebuilding for a friend was broken off completely. The new part number has a reinforcing rib that stops that failure mode.
Old 01-09-2019, 09:49 AM   #10
tmontague
tmontague's Avatar
I hear you man, story of my life right now. The family wont be moving until after next winter and I'm counting the days until I have a garage
Old 01-09-2019, 09:49 AM   #11
CrankyOldMan
I'm in the same boat. I lived in a trailer park or apartment for most of the last 10 years but now have a house with a decent sized garage. I actually did my 2ZR swap in a rented storage unit a few miles from home. Not ideal, but better than an uncovered parking space.
Old 01-09-2019, 08:42 PM   #12
3cyltrbo
Armstrong Racing...........
So this is what I'd love to happen...
I'd like to somehow get you a 5spd / 1NZ-fe compatible transmission (send you mine or source one close to you).
-Have it super super duper cleaned so that its shiny and soo soo brand new looking on the outside
-have that fancy WPC treatment done to the internals
-change the gear ratios (and the final drive?????) so that I don't have a massive RPM drop between 1-2 and 2-3
-change the 5th gear ratio so that I still have super low RPM when cruising on the highway.
= How much $$$$ (PM me if you'd rather take this conversation offline)
Will
p.s. = I already have a Fidanza 8.5lb flywheel and ACT stage 1 clutch just waiting to get installed with whatever tranny work I someday get done.
3cyltrbo is offline   Reply With Quote
Old 01-10-2019, 06:19 PM   #13
myfirstyota
+1 on counting garage days. But I gotta say, so far, hasn't stopped me from doing what I want with my cars :)
Old 01-12-2019, 02:30 AM   #14
ArmstrongRacing
Data doesn't lie
Will
If you want a spare transmission then I can usually find a used one for $300-700, otherwise just mail yours to me in a Home Depot box.($100)
I clean the case on every build I do, no extra cost. WPC for the essentials(3-4-output shaft) is about $200, the whole box is $500.
1st and 2nd include the input shaft, so I wouldn’t bother modifying those, 3rd and 4th can be manipulated in almost any way you like...and 5th gear can be lengthened to accommodate a more aggressive final drive if you choose(requires a new output shaft and ring gear).
My standard fee is $600 labor for the build, and that includes a spec sheet and certification label.
Old 01-12-2019, 09:24 AM   #15
3cyltrbo
So, the way to eliminate the huge RPM drop between 1-2 and 2-3 is through a shortened final drive?
And to get me back to my super lower cruising RPM, a really tall 5th gear is the solution?
Would I end up right back where I am now for cruising RPM?. Even though this car gets sporadic use (its only got 15,000 total miles) , that use can sometimes include 14hrs in a day of highway driving while on trips. Its for this reason that I'm trying to have my cake and eat it to.
WC
Old 01-12-2019, 10:24 AM   #16
tmontague
tmontague's Avatar
I'll chime in as I am using a c50 wth a reduced final drive on stock gears that Tom built. The rpm is about 400-500 higher than it was with the stock final drive what this translates to is much more torque in said gear, especially the first couple. I cant go wot on my slicks from a stop or they will spin even when hot - that is with a clutch type lsd too.
The car now pulls insanely hard for what it is and makes driving pretty engaging. It doesnt actually shorten the distance between each gear as you would have to adjust gear ratios for that, but it shortens the time in each year relative to speed. Think, benefits of a close ratio 6 speed but with a reduced top speed and higher rpm at highways.
Keep in mind I have a 2zr which pulls hard right to redline. The only con I have noticed with the reduced final drive is a lowered top speed (at high speed tracks) and a higher rpm at highway speed which leads to high fuel consumption and noise. For a regular DD'r i would recommend going with a taller 5th gear from a Matrix (Tom can hook you up with the correct one).
IMO a 5 SPD trans with reduced final gear is perfect for the hard pulling 2zr if you have a taller 5th gear installed.
For the 1nz I feel that a 6spd offers more benefits albeit at a higher cost. The reason is that the 1nz falls flat at 5500rpm even with I/H/E installed. The closer gear and extra gear of a 6spd would keep you in the power band. On the 2zr your power band is 4k rpm all the way to redline. So shifting right at redline keep you in the power band . Where as the 1nz power band is about 4k rpm to 5500 so if you shift at 5500rpm you will be slightly out of the power band for a bit.
Someone feel free to chime in and correct anything that I may have got wrong, but I figured my experiences with the trans would be helpful.
Side note, these trans seem pretty stout at sub 150whp levels(and possibly more) and Tom does a fantastic job meticulously installing a trans. You can hammer on it with confidence and trust it will still run the next day
Old 01-12-2019, 07:08 PM   #17
ArmstrongRacing
Data doesn't lie
Completely agree Trevor.
Modifying the 5 speed final drive costs What it does because the final drive is the most expensive part of the transmission. Where the 6 speed becomes more expensive is the new axles and frame modifying.
After having both I prefer the 6 speed due to the 4.5 FD and close ratios...it’s quite amazing. However the 5 speed is definitely no slouch as Trevor, Sam, Jason, Bobby, Garm and so many others have shown.
The thing to ask yourself is....what can you afford and are you ready to make moves?
Old 01-14-2019, 01:35 PM   #18
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Do you know is there's any options for a higher ratio for 6th gear to lower highway RPMs?
I have the C160 in mine and am growing tired of the high RPMs on the highway. I'm turboed too so torque is not an issue.
