#1 |
pink wheels are cool
Rim and Tire Questions
i picked up a set of 15X7 +40 wheels
what size tire should i put on there? 205/50/15? any help would be awesome thanks! |
Shut your fricken suck!!!
205/50's are ideal for that rim size. You will probably rub if the car is dropped, so either get some adjustable camber bolts for the front, cut the piece of the fender liner where your wheels are rubbing, or get some stiff shocks to reduce the rubbing. You could always go gor 195's, but you wont have much sidewall to protect the lips. Good Luck!
#3 |
Drives: 2014 White VITZ Join Date: May 2007
Are you lowered?
You could always check the "Official YARIS wheel & tire guide". |
#4 |
i didnt know we had a wheel and tire guide
really rubbing dropped on 15's? not dropped yet but i was planning on it |
#5 |
Well, if you don't drop, then 205/50's are too short. Go with 205/55's.
If you plan to drop, then 205/50's will work on ET40 quite well, but ET42-45 would be better to avoid possible rubbing issues. |
| Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? | St_G | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 03-16-2011 06:29 AM |
| Has anyone weighed stock rim w/o tire | 50MPGDream | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 08-16-2007 03:56 AM |
| Tire Pressure Max | deebrown | DIY / Maintenance / Service | 82 | 08-10-2007 09:44 AM |
| Need serious Tire and Rim help | thomasward00 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 04-14-2007 01:29 AM |
| Rim sizing - what size to get for OE equivalent? | jay | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 11-20-2006 03:25 PM |
