Old 08-19-2009, 01:06 PM   #1
red_rims
Black Yaris
red_rims's Avatar
Drives: Black Yaris
bird poop is a killer
i left bird poop on my car (left fender) for like 3 or 4 days in the sun. BAD IDEA. now that i finally cleaned it, it seems the acid went through my clear coat. Its not super noticable but its noticable if you look closely at the car. any suggestion anyone?
red_rims is offline   Reply With Quote
Old 08-19-2009, 02:37 PM   #2
stouffer
stouffer's Avatar
Drives: Yaris SR 1.33 - 3 Door
Last time a bird pooped on my car, I didn’t take her out again...
stouffer is offline   Reply With Quote
Old 08-19-2009, 04:48 PM   #3
tomato
tomato's Avatar
I'm interested in any (serious) ssuggestions you might get. Subscribed.
Old 08-19-2009, 07:31 PM   #4
just wash throughout, clay bar, paint sealant and the wax... and wax again.. and again.
You should then be good for a long time :)
Old 08-19-2009, 10:22 PM   #5
06silveryaris
Drives: 2006 yaris
Its really tuff to get out, its really shitty hen that happens(no pun intended)
06silveryaris is offline   Reply With Quote
Old 08-19-2009, 10:57 PM   #6
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
i have that on my front bumper!!!!!!!! Freakin ACID POOP! I am hoping it comes out when i eventually claybar my car.
Old 08-20-2009, 01:40 AM   #7
red_rims
Black Yaris
red_rims's Avatar
Drives: Black Yaris
I just washed my car tonight and it still there! Ima try meguire claybar and quick detailer tommorow. I'll let you guys know how it goes. I had no idea wat claybar is but this video helped me out. http://www.youtube.com/watch?v=yfEfLGL59GI
Old 08-20-2009, 02:05 AM   #8
weedtank
I need more stars
weedtank's Avatar
Drives: Liftback
hate that shit..
weedtank is offline   Reply With Quote
Old 08-20-2009, 02:25 AM   #9
YarisSedan
Drives: 08 Yaris Sedan
try claybar first if not then meguires ultimate compound
Old 08-20-2009, 08:13 AM   #10
Goose
Car Geek
Drives: Yaris Liftback
Clay is good start, but it may not be what you need for poop.
Bird poop damage , as you may already know, is not on top of the clearcoat. Bird poop etching actually eats into the clearcoat, so you reduce the visibility of the damage in response. As with any paint problem, start gently and work your way up to more aggressive solutions.
Clay and wax may indeed hide the poop-stain problem, so there's no harm in trying this first. If cleaning (claying)/waxing don't do the trick, the next step would be to use a mild polish to feather the edges of the stain. Feathering is where you gently polish the edges of the stain to make them less noticeable, thereby making the stain less visible. Feathering should solve the problem, and is really the only solution short of refinishing. I've had very good results with Meguiar's Scratch-X for poop stains. The keys are to have a clean surface, clean applicator, take your time and be gentle - don't make the problem worse.
Waxing the area after polishing will further hide the problem (you should wax after polish anyway). Hope this helps...
Kevin
'07 Blazing Blue 5-speed liftback (sold)
'08 Black auto liftback (sold)
'09 Carmine Red auto 4-door liftback (sold)
Goose is offline   Reply With Quote
Old 08-20-2009, 10:01 AM   #11
DerFlosser
DerFlosser's Avatar
Bird droppings are some of the worst "fallout" you can encounter. The only way to remove bird drop etching is to wet sand and compound/polish. Best done by a reputable body shop. You can use over the counter stuff until the cows come home but you'll never remove it.
I carry a detailer spray and towels in all of my cars and check my car 2X/day for droppings when it's hot and sunny. It only takes a short time before it eats through the clear and....depending on what the bird ate, the results can be immediate.
DerFlosser is offline   Reply With Quote
Old 08-20-2009, 01:57 PM   #12
RedRide
RedRide's Avatar
Originally Posted by DerFlosser View Post
..........I carry a detailer spray and towels in all of my cars and check my car 2X/day for droppings when it's hot and sunny. It only takes a short time before it eats through the clear and....depending on what the bird ate, the results can be immediate.
I do the same thing with my cars. I found out the hard way that you must remover any bird droppings ASAP.
Another paint killer in the summer is tree sap.
Old 08-20-2009, 02:28 PM   #13
mrbond
mrbond's Avatar
Dude, use Meguiar's Ultimate Compound, followed by a good clay bar, and then wax. I had some of that crap on my rear bumper, couldn't get it off with anything else, not even the clay bar by itself.
- A Toyota Yaris
- A whut Yaris?
Old 08-20-2009, 02:30 PM   #14
tomato
tomato's Avatar
+1
I had that on the side of my Honda, could NEVER get rid of it. Careful where you park
Old 08-20-2009, 03:44 PM   #15
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
If you get tree sap and bird poop, you are clearly deciding to park under trees and other objects that sit above your car, try parking in the open =p less chance of everything
Its a Chao!!!
Old 08-20-2009, 10:24 PM   #16
Slick
Slick's Avatar
Drives: '09 3-Dr
I highly recommend Meguire's Scratch-X! I literally Scratch-X 'd my entire '99 chevy truck. I did the whole thing, minus chrome, glass and rims :) The product is designed with micro abbrasives that diminish as you use it. So the odds of you rubbing a worse blemish in your clear coat is slim but could happen with over exposure. So, medium-ish elbow grease will get the job done. Maybe a few applications, but it should come out great.
Old 08-21-2009, 01:08 AM   #17
shaneeezy
<3
shaneeezy's Avatar
Drives: '08 Polar White Yaris S
Send a message via AIM to shaneeezy
Aw, that sucks! I have bird poop stains & dead bug stains ):
shaneeezy is offline   Reply With Quote
Old 08-21-2009, 01:19 AM   #18
tomato
tomato's Avatar
Sometimes you're lucky you can park at all around here, so you take what you can get, you know
bird poop
Killer B Motorsports white delrin shift knob installed! schleppy Cosmetic Modifications (Exterior/Interior) 34 01-27-2010 11:29 AM
Tent to protect against Bird Poop and Grapes captainm27 General Yaris / Vitz Discussion 12 06-13-2009 10:08 PM
Video of Dog Playing with Baby Bird that is borderline dead. PETERPOOP Off-topic / Other Cars / Everything else Discussions 2 01-12-2009 03:27 AM
May He Poop on My Knee .. or Girly Man .. or Benny Lava .. or Indian Nipple Song? Treyz Off-topic / Other Cars / Everything else Discussions 14 12-27-2008 03:10 AM
May He Poop on My Knee .. or Girly Man .. or Benny Lava .. or Indian Nipple Song? Treyz Photo-Video-Media Gallery 2 12-24-2008 07:26 PM
