Old 05-17-2014, 01:37 AM   #1
pidoy
Drives: 2009 toyota yaris sedan
front-right tire rubbing
i replaced my oem wheels and tires of my 09 yaris sedan with 16x7 konig feather, 40mm offset'', 205/50/16 tires, there is rubbing on the front-right side tire every time i turn (full turn) to the left. what is the possible cause of rubbing? and why only in the right-front wheel? thanks for any answers guys..
pidoy is offline   Reply With Quote
Old 05-17-2014, 02:19 AM   #2
pidoy
why it is only rubbing on passenger side when i'm making a sharp left turn? it is rubbing on inner fender. what is the best way to fix this?
Old 05-17-2014, 08:28 AM   #3
My 205s just barely rub on the fender well liner when the wheel is fully turned. It only happens in one direction as well, but I don't remember which.
Old 05-17-2014, 09:10 AM   #4
lambros
lambros's Avatar
Drives: TOYOTA YARIS S 2009
Is rubbing on the fender or to the chassis?
lambros is offline   Reply With Quote
Old 05-17-2014, 02:31 PM   #5
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
well for one ur running a larger tire, should be 195 50 or 205 45 ...but for most part u may have this problem on full lock only
Old 05-17-2014, 04:13 PM   #6
kimona
kimona's Avatar
Drives: 2014 White VITZ
You'll only experience this on full-lock, and it will be very minor rubbing on the fender liner. Nothing to worry about.
Old 05-17-2014, 09:46 PM   #7
pidoy
yes, it is rubbing on the chassis, i just wonder why it is only rubbing on the passenger side.
Old 05-19-2014, 02:07 AM   #8
reggaetonfreak
El Yoe
reggaetonfreak's Avatar
Drives: Yaris Hatchback
funny thing, reason why is rubing on one side is because (at first I though it was my car, but now I hear you guys saying is happening to you) the left wheels, both front and back are about 1/2 inside more than the wheels on the right. I installed a pair of 15x8, +10 offset for autocrossing and noticed this. At first i though the wheels were fucked up. so I took them out and measured them. In the end, I was kinda sad because my car has had this offset since born, I guess bad QA from toyota. This is one of the things I have to fix on my car in the future. Washers hola!!
Cuban to the bone, sitting in a Yaris, ahi si hay!!...
reggaetonfreak is offline   Reply With Quote
Old 05-19-2014, 04:09 AM   #9
lambros
lambros's Avatar
I have the same problem (rubbing chassis) with corolla 16x6 et45 rims and solve it with a good wheel alignment...not big issue...
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 07:29 AM
rubbing up front under heavy breaking regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 05-12-2009 01:23 PM
Tire Pressure Max deebrown DIY / Maintenance / Service 82 08-10-2007 10:44 AM
