Old 09-05-2018, 06:17 PM   #1
timbstir
Drives: 2010 Yaris Seden
Terrible Smell Hard Accel
Hi Yarisworld,
I have a 2010 Yaris sedan 5spd MT, I live on the bottom of a mountain road so I have to drive up and down to get to school (grad student), last I started to notice that when I'm hard on the throttle to get up the hill I get a terrible smell. I can't tell where its coming from and it's hard to describe, its not brakes (I know that smell) and it's somewhere between an oil smell and a rubber smell. I only notice the smell when I keep my foot down (basically only going uphill for a long time). I'm not seeing white smoke, or smelling oil normally, and my oil level hasn't dropped at all. Also just clicked 125k miles and switched the spark plugs and didn't see any signs of oil burning on the old ones, so I don't think I'm burning oil in my combustion chamber. Was wondering if anyone has experienced this problem before and knows the cause.
Thanks
timbstir is offline   Reply With Quote
Old 09-06-2018, 12:34 AM   #2
CoryM
Drives: 2009 5-door, 5-speed
Check for the leftovers of a melted bag on your exhaust.
If it's a manual trans, could be clutch burning. Makes a very acrid smell.
Old 09-06-2018, 02:33 PM   #3
timbstir
Nah it's not clutch, I had one die on me before I know exactly what that smells like. I don't see a plastic bag under there either.
Old 09-06-2018, 04:51 PM   #4
Exhaust leak from the notorious donut gasket that goes bad?
Old 09-07-2018, 12:44 AM   #5
komichal
It would be good to stop when the smell is there again. Open the hood and check the engine. There can be some light smoke coming somewhere, it may guide you better. Or you may not see anything there, you may realize that the smell is not coming from the engine... etc.
Old 09-07-2018, 07:50 AM   #6
nortonfb
Drives: 2007
Could it be a critter? Seen it a few times.
Worst was a squirrel for smell. Found on the back of a Corvair motor/body.
At idle the stench was awful, Drive and it dispersed until you stopped
nortonfb is offline   Reply With Quote
Mga Bagong Kayaris ! ! ! syntax Middle East 749 04-26-2021 02:40 AM
Burnt smell in cabin at high speed in cold weather grilled cheeseus DIY / Maintenance / Service 13 12-15-2018 07:29 PM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
New Car Smell or New Sneaker Smell....Which is better? KCALB SIRAY Off-topic / Other Cars / Everything else Discussions 12 01-04-2010 09:54 PM
Coolant Smell after sitting in hot sun? Snappy General Yaris / Vitz Discussion 3 05-31-2009 12:18 AM
