Old 02-19-2010, 04:52 AM   #1
Toy Yaris
Drives: 2nzfe 3dr Yaris
Has any1 got a 1zz tb that sucessfully works
Hi guys,
I've ordered a 1zz tb now i'm wondering if i should cancel it as most of the posts here a negative about the 1zz tb. I want to know if any one has done this successfully and does it actually make a difference? if so can you please explain the process that needs to be done please.
thanks
Toy Yaris is offline   Reply With Quote
Old 02-19-2010, 07:42 AM   #2
Maitre_Te_Te
Drives: Yaris 08
I have one 1zz TB and it work great when engine hot. No CEL, just fine with a litlel bug at 3000 if I release de gaz, it maintain, but for me, this is not a big probleme. I will do a chip swap with 2 Spare TB (1zz and 1nz)
Maitre_Te_Te is offline   Reply With Quote
Old 02-19-2010, 01:43 PM   #3
1. Take a stock 1NZ throttle body, and drill out the rivets that hold the plastic controller to the body. Do the same thing with your 1ZZ throttle body.
2. Chip away the protective sealant on the 1ZZ's adjustment screw.
3. Use small bolts/nuts to install the 1NZ "chip" (black plastic end) onto the 1ZZ throttle body.
4. adjust the screw as needed. The screw determines how open the plate is at idle. If you're revving too high at idle you'll have to back this off by adjusting the screw.
Disconnect the battery for a while to force your motor to go into relearn mode (I can't remember how long).
Does that help?
Old 02-19-2010, 02:47 PM   #4
kngrsll
Apexing Egg!!
kngrsll's Avatar
Does that help?
did know you could do that?? cool...
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 02-19-2010, 04:51 PM   #5
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
I didnt need to adjust anything. Just a chip swap was fine the ecu can adjust the idle by itself.
Yoda is offline   Reply With Quote
Old 02-19-2010, 10:34 PM   #6
Toy Yaris
Does that help?
Thanks yes it does help, but do i swap the electronics or the whole black plastic thing?
Thanks again
Old 02-19-2010, 11:11 PM   #7
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Yeah just replace the black plastic base and it'll work.
Old 02-20-2010, 12:17 AM   #8
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
good luck.
Old 02-20-2010, 05:55 AM   #9
Toy Yaris
I guess i will give it a go will be getting it in a few weeks as a mate owes me money . now coolant lines connect or bypass??
and the tb gasket do you use the old 1 or just use sealastic, i was thinking of using the old gasket and toyota black sealastic ??
Old 02-20-2010, 09:36 AM   #10
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
undefined
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 02-20-2010, 09:46 AM   #11
tk-421
tk-421's Avatar
Drives: 5D-07-LB
bypass
Old 02-20-2010, 10:20 AM   #12
xxae07xx
hook em
xxae07xx's Avatar
Drives: black 08 lb
i dont understand why ive never had problems with my tb...i never swapped chips or any of that stuff. revs oscillated for about 10 after the swap and that was it. no cel or nething and that was a good yr and a half ago...
xxae07xx is offline   Reply With Quote
Old 02-20-2010, 12:53 PM   #13
That is where the electronics are.
Most trouble occurs because of sealing/gasket problems. Make sure to use the rubber O-ring. You'll notice it has one spot that leads to the outside of the TB. So, if you don't use that gasket (or seal it properly with other material), you will have a leak.
Old 02-23-2010, 07:28 AM   #14
Toy Yaris
Cool thanks guys will give it a go, will let you know how it goes..
1zz injectors suit the S/C just fine LtNoogie Forced Induction Forum 51 04-30-2016 11:11 AM
Works bell/Nardi quick release steering wheel setup blacksandiegovitz Cosmetic Modifications (Exterior/Interior) 35 09-02-2009 06:52 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 09:52 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
