#1 | |||
The Scion Guru
Drives: Scions Join Date: Feb 2007
New Engine Management System offered for the 1NZFE
We are pleased to announce the Allan Phillips Racing In-Line ECU for the 1NZFE platform. Today we had successfully gotten it to run on a 2009 Yaris S and are ready to offer this wonderful unit.
Some more info to chew on: Introducing the ultimate powertrain management system for the Toyota 1.5L 1NZFE. The X-One has been designed to take complete control of the injection and ignition systems to allow absolute management of powertrain operation without upsetting the factory ECU and its diagnostic systems. This enables the X-One to adjust every aspect of the powertrain calibration including rev-limiter extension since it drives the injectors and igniters directly as a true ECU. Allan Phillips Racing and Dezod Motorsports together have engineered a complete system that unleashes the reserved horsepower in your Toyota 1.5L powertrain. .A true parallel processing ECU with extended Rev-Limiter Adjustable Soft-Cut Rev-Limiter Control (internally limited to 6500 RPM). Increased rev-limiter calibrations (up to 7800 RPM) are available from Authorized Dealers for highly modified race engine that are designed to handle the increased loading. Contact us about your desired rev limiter. True Plug and Play Technology A full wiring harnesses is used to adapt to system into the vehicle. It simply plugs into the factory ECU and harness using OEM connectors. Utilizes all factory sensors with the option of using high performance aftermarket sensors as well. Complete Fuel Control High-resolution map tables (20 x 24 cells) enable precision fuel adjustments during both closed and open-loop operation. Calibrations for oversized mass air flow sensors (up to 900 cfm). A sophisticated mass airflow based fuel controller senses OEM injection, desired air/fuel trajectory, WRAF sensor feedback and many other internal signals. The X-One calculates injector and igniter updates 200 times a seconds to provide high-bandwidth control. (Forced-induction compensation up to 200% engine load and 7800 RPM) The table ordinate breakpoints may be adjusted to accommodate any range. Users tune the commanded air/fuel table with adjustments for trimming and dynamic fuel compensation. The calibration is entirely based upon engineering units (no fudge factors based upon injector duty-cycle, or MAF/ECT voltage). Advanced forced-induction auxiliary injection system controls secondary port and throttle injection. This control option enables the ability to keep the factory injectors stock with high quality performance, drivability and emissions. The oversized main injector function allows the replacement of the stock injectors as well. This control activates the secondary injectors based upon load calculations with a calibrate-able distribution between the port and throttle injectors (chemical intercooler feature). Complete Ignition Control High-resolution map table (20 x 24 cells) enables precision spark adjustments keeping the OEM knock control intact for durability. Mass airflow based load calculations accurately senses the cylinder conditions for precision spark delivery to 0.1’ (36 tooth accuracy). Spark advance and retard capability allow for modified intakes, exhaust systems and forced-induction configurations. USB High Bandwidth Acquisition System The power of USB unleashes the data acquisition capabilities normally found only in expensive high-end systems. XTune can capture over 100 parameters at 100 Hz for 100 minutes of data recordings. 18-Channel Auxiliary Measurement Port In addition to the internal 18 sensor channels, the X-One includes an external 18-channel auxiliary data acquisition port. These channels are available for auxiliary measurements for pressure, temperature (RTD), thermocouples, UEGO and digital mass airflow sensors. All together, the XTune software package includes 36 sensor channels that allow for advanced data acquisition analysis. Included with X-One is a generic harness for connecting auxiliary measurements. Any Q's....feel free to ask!
Dezod Motorsports Inc-'We ARE performance." P: 716-681-6666 E: sales@dezod.com W: www.dezod.com Your leading source for all of your performance needs! From turbos and components, to brakes and suspension, Dezod has you covered. Last edited by Dezod; 08-06-2010 at 02:25 PM. |
| The Yaris Performance Primer | eTiMaGo | Performance Modifications | 30 | 01-24-2024 04:26 AM |
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| wtb 1nzfe engine blown or working | turboyaris | Items for Sale by private party | 5 | 04-08-2007 02:03 PM |
| Engine Management | machine1 | Performance Modifications | 17 | 02-22-2007 11:26 PM |
