![]() Drives: 09 LB, 3 door, auto Join Date: May 2009
sway bar is bad for the tires
I installed a 23mm sway bar a couple of months ago, I love how the car drives now, but I've noticed that the tires started to peel off pieces, like skin flakes. I think its because I take turns about 50% faster now.
やりすぎだ~
*first in line to buy petyanca's swaybar!* :P
#3 | |
LOL
that is some funny stuff. Drive smoother, Garm! |
Driver or not, car allows for faster turns now, but tires become the weak link. I still have stock tires, they are a harder compound tires but ok for now. When they wear off if I put softer tires on would they do better in terms of peeling off flakes?
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
u need a Big Brake kit ! to slow you down on the corner .
^ You're supposed to be done with your braking in the turns.
That might be your real problem. Stock Potenzas suck pretty bad.
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
yea the OEM tires are a softer compound and don't last very long, mine wore out in under 25k miles. partially because the place i used to live had 180 degree turn to get in, it was fun :D
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
my RE92's lasted almost 60,000 miles
Driving behavior makes all the difference.
#12 | |
Cheers. Cory PS: I figure if you don't put tires on your fun car no less than every two years, you aren't having enough fun. Then again, I use R-comps for street tires.... |
Back before I ever heard the term drifting (early 90's), I used to go through a bunch of tires on a hot rodded camaro z28.....from brand new to belts showing in about a month. I had lots of fun!
no show, no go :(
![]() ![]() ![]() Drives: Yaris Hatchieback Join Date: Jun 2010
Its all depend on what rate of tire you get and how you drive it. I got Pirelli P4 all season and it last me for long time. High speed and hard corner no problem. I got 5 bars in the rear. No body roll at all.
| Tags |
| sway bar, tires |
| My Ultra Racing rear sway bar install | CtrlAltDefeat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 49 | 03-03-2011 02:08 AM |
| TRD Rear Sway Bar | detroiter | Items for Sale by private party | 15 | 08-05-2009 01:01 AM |
| sway bar... Toyota dealers must be insane! | RedRide | General Yaris / Vitz Discussion | 10 | 07-24-2009 03:39 AM |
| Sway bar and struts | DOMAV | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 07-17-2009 02:26 AM |
| TRD sway bar and tire wear | Cutie Pie #2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 26 | 02-01-2009 08:07 AM |
