![]() Drives: Toyota Yaris 1.3hb Join Date: Apr 2007
How to drive my 2007 Yaris forever
I've had a 2007 Yaris since I got it new, and it now has just under 100,000 km on it. I love the car and would like to keep it as long as I can, but after my recent mandatory technical check (every two years here in Czech), it's still approved for the road, but the items listed on the report suggest that time and rust/corrosion are my main enemy. I had nothing listed two years ago and maybe the tech was just nicer last time, but this time it's:
Recognizing that it can't last forever can anyone suggest any preventative steps I can take so it doesn't rust out before its time?It is driven in winter, and has been in a slightly heated garage for the last few years. I don't regularly wash the undercarriage, for example. If some minor corrosion has started, is washing it still a good idea? Can I protect it somehow? Otherwise, I take it once a year or as needed for routine maintenance, but it hasn't needed any major work so far. Thanks for any ideas... |
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
Here in Canada, oil spraying your car is popular for rust prevention. If you spray it now, it would be like hitting the pause button. You'll still have the rust you have now, but shouldn't get much worse.
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
Get a gallon of Fluid Film & an airless paint sprayer, have at it. Get inside the rockers too.
#4 | |
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
Sent from my SM-G900F using Tapatalk
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
Thanks everyone for the ideas. Any tip on what is available here in Europe? I can go see what's available at the local parts store and report back, but would be glad to know what to avoid. I do have concerns about oil spraying, environmentally, at least.
Hold on, I think I found the stuff here, does this look right?
https://www.stop-koroze.cz/fluid-fil...erosol-400-ml/ |
#7 | |
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
Parking in a heated garage during the winter is harmful because the road salt that coats your car (especially the underside) will cause corrosion quicker at a warm temperature. At very cold temperatures the effects of road salt are minimized which is why cars from more extreme winter climates survive with less rust than those from mild winter climates. Last edited by B.B._07; 03-12-2019 at 08:39 PM. |
My 2007 Yaris rusts as well, obviously Czech Republic is rust-positive :(
I will see what my "STK" indicates in July, I may quickly become interested in exactly the same topic. However... does it make sense for car with 250,000 km ? |
#9 | |
I think with STK it depends who the technician is. The guy two years ago was friendly and the report was "clean", žadné problémy. I don't think that much changed so fast. The tech this year was listing everything he could. It was lucky I just restored one headlight that was yellowing (by sanding and clear-coating it), because he tested the headlight intensity and I would have failed for sure.If this spray works, in my opinion it still makes sense for a car with high kilometers, if it doesn't have anything else major wrong. Even if you have to spend 2000 Kc on it, the cost of replacing a frame or suspension part will be much higher, and at that point you'll think about a new car. Each year you don't have to buy a new car is worth a lot for the wallet and environment. |
![]() ![]() ![]() Drives: 2003 Mach 1 Join Date: Oct 2008
I've got 360k miles on mine... which translates to about 579,000km. Just oil changes, belt changes, general maintenance, one starter, 2 alternators, and like 4 batterys
![]() Actually just bought a 2019 Corolla to take over in the event of catastrophe because this is uncharterd territory for me with a car... I'll continue driving the Yaris until something major happens, garage it, and eventually get it fixed. |
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015 Join Date: Mar 2012
you can look at these videos of how a professional rust profing is made here in denmark.
Its pretty normal to get i done here, because we are in the salt and moisture belt. https://www.youtube.com/watch?v=VBkdqwwPRVk&t=221s https://www.youtube.com/watch?v=GU8amOp9S00&t=2s My old carina E/corona from 97 was almost rust free when it went to africa in 2017, but it had also got plenty of rust profing in its lifetime.
Yaris Hybrid Limited 2015 C-HR 1,8 Hybrid premium 2020 |
Wow, I can see how the professional equipment makes it much faster, and probably better. So I'll see if I can find anyone who does it here in Czech, otherwise I'm not clear on what to hit with it and what not.
How heated is your garage? Anything over 7°C is bad IMO. I came to accept it my car won't last much longer. My 07 Yaris bought in 06 is 13 years old this year. Hopefully I can get it to 15-16 years, but I don't have much faith in it. It is starting to require quite a bit of repairs.
This summer I am going to repaint the 2 front fenders. It has started last rusting last year, now it's just horrible around the arch. Windshield is starting to get unglued from 2 of the 4 corners. You can see moisture inside. Exhaust is leaking around both joints where there are the gasket donuts. Chassis rust has hit under chassis in 2012 when I parked in a 15°C garage 2 years prior. Clutch is getting tired. I got a fidenza flywheel, but not sure if it's worth the effort to spend time and actually replace the clutch. Sent from my CLT-L04 using Tapatalk |
#14 | |
It can be 10C in the garage, and unfortunately can also be humid sometimes if the cars come in wet, even if we try to clean them (two car garage).I thought the garage would be better for it, but the rusting underneath has accelerated and my steel wheels for winter went from rustless to covered in it in two years. Previously the car had been parked outside. I have the option of parking it outside under a carport, and I think I'm going to start doing just that, in addition to having it oil sprayed. The climate is cold here. This is really helpful, thank you. |
#15 | |
#16 |
![]() ![]() ![]() Drives: 2009 5-Door Liftback Join Date: Jun 2011
I have a silly question. I live in one of those mild winter climates. We can have freezing rain or five inches of snow one day, and then a few days later it warms up to 40 degrees. Oftentimes, on those mild days following a deep freeze, it rains. I avoid driving when the roads are salted as much as possible. I take the city bus to work and I live within walking distance of a grocery store, so I have the luxury of choosing not to drive if I don't want to. However, there have been a couple of times this year when I did have to drive on a freshly-salted highway. When that happened, I would take a long highway drive during the next big rainstorm, with the idea that the heavy rain would wash all the salt off the undercarriage. Would this actually work? Is driving in the rain a good way to clean off the undercarriage and prevent rust, or does it not actually do anything?
#17 | ||
Heated garages are great but should be left for the summer cars or ones that ar not driven in salt. Quote:
I don't think what you're doing is bad, but your best bet is to have the car oil sprayed every spring once the salt is off the road and the temps rise. At least if you want the car to last as long as possible. Nothing else will do nearly as much to protect it except not driving it at all during the winter.
#18 |
When I do my drives through the rain, I'm pretty sure that all the salt is washed off the road. Lately, we've been having very intense rainstorms a few days after a serious snow. Rain so intense, that I can only see the taillights of the car in front of me, and I have to concentrate extra hard to see the white lines.
I will look into oil spraying my car. I'm sure there's plenty of YouTube videos that show how to do it. So far, the body of my car is in perfect shape, just some very, very minor surface rust on some parts of the undercarriage. I really like this car, and I want it to stay in great shape for a long, long time. |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| Need help... 2007 Yaris with Aux plugin | molinee | In Car Entertainment + Electronics (audio / video / alarm) | 18 | 02-20-2015 12:01 PM |
