![]() Drives: 2007 Yaris LB Join Date: Aug 2009
Have Insulation - Where should I stick it? (07 LB Road Noise Reduction)
Installing new head unit + speakers this week. Thinking now is a good time to do *some* road noise reduction.
I don’t care to gut the car and do it fully (at this point). Focus: easiest areas that make the biggest difference. I have 2 types of padding on hand. 1) 80 mil sound deadening Noico. 36 sq ft 2) 2-faced foam padding like in pic below. It’s leftover from another non-car project and I have enough to wrap the whole car in it. Maybe 1/2” thick. Plastic barrier stuck to both sides. Given the supplies above, where would you recommend putting them to reduce some road noise? ![]() ![]() Sent from my iPhone using Tapatalk Pro
Keith, 2007 Yaris Liftback YouTube: Keith's Test Garage | http://www.KeithsTestGarage.com |
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
I know you said you did t wanna gut the car but if you remove the inside rear quarter panels, it exposes the outter sheet metal and wheel wells. I did this to one of my cars. I did the whole inner rear quarter, the wheel well and the trunk floor. Made a decent difference
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
#3 | |
Safe to assume you ran it under the spare rather than laying it on top?
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
I actually just pulled those plastic panels out of my car hunting a pesky water leak. It only takes 10 minutes and it exposes a shitload of bare metal. Definitely a good place to start.
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
My whole car was gutted. I laid it everywhere there was metal. Did the entire floorpan from the pedals back, inner rear fenders, the wheel wells and the hatch. Some of these areas are double thick. I picked up another box to do the doors next spring.
Tip: if you're using the butyl stuff that you need a roller for, I highly suggest making your own roller from a metal castor and a threaded rod. The ones you buy online send to really suck and break easily. I made 2 different sizes and they worked great. Applying on a hot day helps with adhesion too.
| Compilation of Yaris TSBs | eTiMaGo | DIY / Maintenance / Service | 72 | 07-04-2024 11:36 AM |
| Help With Reverse Noise???? | JoshW | DIY / Maintenance / Service | 0 | 09-09-2011 01:27 PM |
| Strange noise coming from left door of car | daibatzu | General Yaris / Vitz Discussion | 3 | 11-19-2010 10:58 AM |
| Low road noise in Yaris? | RedRide | General Yaris / Vitz Discussion | 32 | 05-30-2010 09:49 PM |
| Radio noise.. need help | TinyGiant | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 12-06-2008 05:21 PM |
