Old 07-18-2019, 07:19 AM   #1
tinabee1967
Yoda
Drives: 2015 Yaris
2015 Hatch suspension options.
I love my 2015 hatch, but would love to get rid of the body lean. Would a thicker rear sway remedy this, or would I have to get coilovers? Lowering it would not bother me as long as it's not TOO low to roll on my mechanic's lift. Am I correct in assuming earlier year's parts will fit the '15 hatch?
Thank you, in advance. I am coming from the reference of being a former Miata owner with a modified suspension which sort of spoils me regarding handling. 😆
tinabee1967 is offline   Reply With Quote
Old 07-18-2019, 08:36 PM   #2
xxcanuckxx
Drives: 2015 SE HB
Mark me down as interested as well! Just purchased a 2915 5 door SE, and already do not like the body roll. Which confuses me a little, because I thought they beefed up the SE handling.
I also have a full set if Eibach springs for an XD, does anyone know if I could use those?
TRD Part numbers for reference
I can't get these in Canada, but as I understand, people have had success at US dealerships...
Rear Sway Bar - Toyota (PTR11-52071)
Performance Shocks - Toyota (PTR04-52061)
Spring Kit - Toyota (PTR11-52070)
TRD Sport Muffler Part No.: PTR03-52081
Quick Shifter - Toyota (PTR46-52081)
Splash Guards, Set Of Four - Toyota (PT769-52090)
Sent from my SM-G950W using Tapatalk
xxcanuckxx is offline   Reply With Quote
Old 07-20-2019, 10:05 AM   #3
myfirstyota
3 Yaris and counting..
I have tein stech springs in my 2zr swapped yaris (they have been in all of my yaris at one point or another) and if I remember correctly, they are listed as fitting the xd and yaris from tein.
My beater yaris is currently sitting on stock xd springs. Being thicker material, they are much stiffer than stock yaris springs, resulting in better handling and about 1-1.5" of lift.
Check out micro image on eBay.
https://www.ebay.com/itm/Toyota-Yari...4AAOSwRF1b8xdv
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 07-18-2019, 11:03 PM   #4
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
You are correct. The suspension is essentially the same for all model years. Any aftermarket parts that fit one year will fit all years.
Old 07-19-2019, 07:23 PM   #5
tinabee1967
Yoda
Drives: 2015 Yaris
Thank you! :)
Old 07-19-2019, 08:02 PM   #6
heeroyuy01195
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles
Hey! A fellow Floridian! If you don't mind the cost of coilovers, I would suggest going that route. I'm running a stock front swaybar and coilovers on my 07, car handles perfectly for some spirited driving on the street. Good luck!
heeroyuy01195 is offline   Reply With Quote
Old 07-22-2019, 07:17 AM   #7
tinabee1967
Yoda
Drives: 2015 Yaris
Where are you located? I am in SWFL. I am not sure which coilovers I want, maybe Tein Street Basis since they are not too crazy. I am also thinking of getting a rear sway.
Old 07-29-2019, 08:14 PM   #8
xxcanuckxx
Drives: 2015 SE HB
I have been on this site for years and the number one handling upgrade that everyone recommends is a rear sway bar. TRD being the easiest to install, and there were others that liked the Whiteline one.
As far as coil overs, they are not a great option anywhere in the snow belt if you want to drive your car in the winter, too many problems with the bits seizing. But, with you being in Florida, coilovers are a great option if you are willing to pay the price. Tein is a good name and they have been put on the Yaris a lot over the years.
2015 Yaris SE (m/t) - Week-One Impressions - The Good, The Bad, & The Ugly. Kalispel Third Gen Yaris General Discussion 53 04-29-2016 10:35 AM
2015 Toyota Camry Kal-El Off-topic / Other Cars / Everything else Discussions 9 04-18-2014 06:47 PM
Finishing my suspension ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-15-2011 09:26 PM
Any Yaris hatch rear suspension tweeks? woof Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 12-05-2009 06:04 PM
