![]() Drives: 2012 Yaris coupe Join Date: Feb 2017
2012 yaris assembled front wheel hub
So I believe it’s time to replace our cars wheel bearings it’s starting to make noise. I plan on checking for play in the wheels later.
Anyhow I called autozone and orileys and neither place has a completely assembled hub with bearing preinstalled. Does anyone know of anywhere online where I can purchase a pair of assembled hubs ready to go? I can’t find them on rock auto or amazon either. I understand the bearing is replaceable but I find it a whole lot easier to just swap out hubs since I don’t have a press or any machining tools. |
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
Not sure you can buy the knuckle with bearing installed. The yaris isn't built with a replaceable hub/bearing unit but rather a bearing that's pressed into the steering knuckle.
Your best/cheapest solution, I believe, is to remove the knuckle yourself and bring it to a shop to have the bearing pressed out and a new bearing pressed in. This will save you the labour to have the knuckle removed from the car by the shop. Pressing the bearing out and the new bearing in should only take a few minutes. My shop charged me $40 to replace the bearing last time I needed one done. I just brought them the knuckle. Not the whole car.
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
| Wheel bearing / Outer TRE / Control Arm replacement howto | shepd | DIY / Maintenance / Service | 3 | 09-14-2015 05:20 PM |
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 04:55 AM |
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 02:41 PM |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
