Old 10-09-2021, 09:59 AM   #1
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
2ZR life expectancy?
I read that the 2ZR-FE block is all aluminum....there are no steel sleeves in the piston bores. Because of this the engine bore cannot be bored oversize and the engine rebuilt. How long do these engines last in the real world?
My 1NZ-FE has 250,000 miles on it and runs perfectly. I have no doubt it is good for another 250,000 miles with just oil changes.
Is a 150,000 mile 2ZR from a junk yard at the end of its life now?
Also, anybody swap pistons from a 2ZR-FXE into a 2ZR-FE for 13:1 compression? Curious if it runs ok on 93 octane.
Old 10-11-2021, 04:11 AM   #2
RomanDave
Drives: 2NZ ITB NCP10
They definitely will have steel liners!
But they will just be thin and cast into the block in such a way that there's not enough to bore them out any further.
RomanDave is offline   Reply With Quote
Old 10-18-2021, 06:07 PM   #3
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
450,000km on my 2zr, still ran daily duty when pulled. No clue how it was treated prior to when I got my hands on it at 350,000km. But judging by the mess of the donor car, I'd say it didn't have a perfect maintenance history. However I can say the last 100,000km it took a beating. WOT daily. Regular oil changes @ 5000km. I'd put it back in if there wasn't a hole in the intake manifold (no fault of the engine).
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Old 10-18-2021, 06:14 PM   #4
Flipper_1938
That is good to hear. When I read about them having an all aluminum block, I had flashbacks to the chevy vega engines. They were throw away engines after 40,000 miles or so.
Old 10-18-2021, 07:14 PM   #5
myfirstyota
The engine will outlive the car in most scenarios if cared for. Hell, just change the oil and throw an air filter at it once in a while and you'll go a long ways with it. What one would describe as "bullet proof"
Old 10-25-2021, 10:36 AM   #6
Flipper_1938
That is the way I feel about my 1NZ-FE.
My sedan is still rust free/wreck free...I would love the extra power but would hate to find out that the junkyard motor had issues.
Old 10-26-2021, 06:21 AM   #7
Calrenman
Drives: 2015 Toyota Yaris LE Hatchie
Nice to hear. I have a 2015 with forty four thousand miles on the clock and i do not think it is broken in! The first 17K where Grand ma miles then she gave it to me! I am so lucky! :)
Calrenman is offline   Reply With Quote
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 05:59 AM
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 12:56 PM
Dropping the tans in a 2zr swapped Vios tmontague Performance Modifications 2 04-29-2017 08:29 PM
Yaris life expectancy birdman General Yaris / Vitz Discussion 18 05-30-2010 01:44 AM
How to Be a Street Racer - General Life Guide MDF Off-topic / Other Cars / Everything else Discussions 7 03-19-2007 01:49 PM
