Old 08-04-2010, 11:07 PM   #1
Dezod
The Scion Guru
Dezod's Avatar
Drives: Scions
New Engine Management System offered for the 1NZFE
We are pleased to announce the Allan Phillips Racing In-Line ECU for the 1NZFE platform. Today we had successfully gotten it to run on a 2009 Yaris S and are ready to offer this wonderful unit.
Originally Posted by Dezod View Post
Ok. I do not get on this board too often, however let me enlighten those whom are unfamiliar with the Allan Phillips Racing systems.
The unit is an In-Line ECU. It is not a piggyback, and is not a standalone. It has properties of both and I will explain how and a lot of the cool functions it has to offer.
First, it has full closed loop and open loop fuel control. Most piggybacks do not offer both like the E-manage Ultimate, E-manage, S-AFC, Neo, FIC.....These unit s struggle (at best) to control the AFRs well and tightly around the stock ECU's strategy. The APR X1 does it flawlessly (if programmed properly). There is no pulse widths to enter like a standalone. There is no duty cycles to enter. There is no BS. Just enter the target AFR based upon load and engine RPM and be done with it. The tighter your injector transfer function is, the tighter the AFR control will be. The thing is SUPER accurate and provides mounds to data for easy tuning and no guess work.
Secondly, ignition timing is more like a piggyback in the fact that it lets the stock ECU make the final call for what it determines as far as spark advance. Your Spark Base table tune (allowing for both advance and/or retard) will provide an additional figure below or over the stock value. For example, say the stock ECU wanted 20 degrees at WOT, and you wanted 25, simply add +5 in those cells and be done. A negative 5 would yield 15 degrees of advance. This makes it easy and eliminates all of the guess work involved with ignition timing.
You can also alter the top speed, rev limiter, you get 2 step launch control, still works with ALL factory keys, accessories and such like a stock car. The OBD2 port is still active for emissions purposes for those of you whom have emissions in your area (unlike a standalone). All trouble codes are still active and in use too.
The real benefit of a unit like the APR is that is uses all of Toyo's millions of dollars of invested time and equipment to your advantage. Toyo spent countless man hours developing ECU fuel and ignition mapping strategies that you can now use to your advantage using the unit like the APR. The fact that you can custom sculpt a fuel curve and ignition curve with minimal effort and supreme accuracy is second to none.
If you become proficient with the APR unit, you do not even need a dyno to tune it. You can view the super sophisticated datalogging, make changes and see the air flow difference from one pull to the next. It doesn't get any better than that. Same deal for ignition timing too. You can see where knock occurs and when the stock ECU pulls out timing, and adjust accordingly. No fussing with custom knock curves and such.
I have tuned plenty of standalones and owned a complete standalone Lexus IS300 that we did with an AEM EMS, and this APR is second to none. The amount of data you can get and have from pull to pull, you don't even want to touch another system. My current DD has a custom APR on it, and it's an xB2. I love the darn thing! No cold start adjustments, no start extra fuel decay maps, no prolonged stat sync starts....Just turn key and go.
I will entertain and all questions regarding this unit and post datalogs and shots of the software to show that this unit is the future of modding Toyos.
No control over VVT. To be honest, we offered it in the AEM EMS we did for the Scion tC. Most people did not take the cumbersome efforts of tuning it, so it was left by the way side. The ARP lets the stock control it, which works just fine as it does a good job (not the best) in controlling it.
WHY WOULD YOU WANT TO RUN SPEED DENSITY!?!?! You are out of your mind if you want to do this! Use the MAF as the APR was designed to do. The MAF is MUCH more accurate and provides baro change correct, temp and humidity correction all in one. With MAP (Speed density) you must do that on your own. Stick with the MAF, use it's accuracy and be done with it. (also, don't worry about maxing it out, if you do you can run a GM 650g/s^2 MAF with the APR or even twin MAFs!) Take the 3D modeling of air and enjoy.
As far as cams, we've done 264s on the 2AZ tC without issues at all. We are now about to do some 280/272s to see what's up. I would not be concerned with cams and this unit at all. We've even run 850cc injectors too. No problems there either.
Some pics!
Well again, it all boils down to demand. A turbo kit (to do it right) encompasses a lot of cash outlay to put units on the shelf and such. Just to put the point home, if we had taken the same approach as we did with the tC kit, where we put 100 units of downpipes and intercoolerpipes on the shelf, we'd be up poop's creek in this market. The tC market embraced our enthusiasm and bought it all and then some many times over.
I guess the point I am driving at here is demand. There needs to be people wanting and buying a product for it to exist. It must be a profitable venture for a company to undertake the challenge.
The engine management deal, can be done on a one or two unit basis, therefore requires virtually minimal cash outlay therefore offering a better change of existence to the market.
This unit allows for turbo, S/C and N/A tuning with no problems!
Some more info to chew on:
Introducing the ultimate powertrain management system for the Toyota 1.5L 1NZFE. The X-One has been designed to take complete control of the injection and ignition systems to allow absolute management of powertrain operation without upsetting the factory ECU and its diagnostic systems. This enables the X-One to adjust every aspect of the powertrain calibration including rev-limiter extension since it drives the injectors and igniters directly as a true ECU.
Allan Phillips Racing and Dezod Motorsports together have engineered a complete system that unleashes the reserved horsepower in your Toyota 1.5L powertrain.
.A true parallel processing ECU with extended Rev-Limiter
Adjustable Soft-Cut Rev-Limiter Control (internally limited to 6500 RPM). Increased rev-limiter calibrations (up to 7800 RPM) are available from Authorized Dealers for highly modified race engine that are designed to handle the increased loading. Contact us about your desired rev limiter.
True Plug and Play Technology
A full wiring harnesses is used to adapt to system into the vehicle. It simply plugs into the factory ECU and harness using OEM connectors. Utilizes all factory sensors with the option of using high performance aftermarket sensors as well.
Complete Fuel Control
High-resolution map tables (20 x 24 cells) enable precision fuel adjustments during both closed and open-loop operation. Calibrations for oversized mass air flow sensors (up to 900 cfm). A sophisticated mass airflow based fuel controller senses OEM injection, desired air/fuel trajectory, WRAF sensor feedback and many other internal signals.
The X-One calculates injector and igniter updates 200 times a seconds to provide high-bandwidth control. (Forced-induction compensation up to 200% engine load and 7800 RPM) The table ordinate breakpoints may be adjusted to accommodate any range. Users tune the commanded air/fuel table with adjustments for trimming and dynamic fuel compensation. The calibration is entirely based upon engineering units (no fudge factors based upon injector duty-cycle, or MAF/ECT voltage). Advanced forced-induction auxiliary injection system controls secondary port and throttle injection. This control option enables the ability to keep the factory injectors stock with high quality performance, drivability and emissions. The oversized main injector function allows the replacement of the stock injectors as well. This control activates the secondary injectors based upon load calculations with a calibrate-able distribution between the port and throttle injectors (chemical intercooler feature).
Complete Ignition Control
High-resolution map table (20 x 24 cells) enables precision spark adjustments keeping the OEM knock control intact for durability. Mass airflow based load calculations accurately senses the cylinder conditions for precision spark delivery to 0.1’ (36 tooth accuracy). Spark advance and retard capability allow for modified intakes, exhaust systems and forced-induction configurations.
USB High Bandwidth Acquisition System
The power of USB unleashes the data acquisition capabilities normally found only in expensive high-end systems. XTune can capture over 100 parameters at 100 Hz for 100 minutes of data recordings.
18-Channel Auxiliary Measurement Port
In addition to the internal 18 sensor channels, the X-One includes an external 18-channel auxiliary data acquisition port. These channels are available for auxiliary measurements for pressure, temperature (RTD), thermocouples, UEGO and digital mass airflow sensors. All together, the XTune software package includes 36 sensor channels that allow for advanced data acquisition analysis. Included with X-One is a generic harness for connecting auxiliary measurements.
Any Q's....feel free to ask!
Dezod Motorsports Inc-'We ARE performance."
P: 716-681-6666
E: sales@dezod.com
W: www.dezod.com
Your leading source for all of your performance needs! From turbos and components, to brakes and suspension, Dezod has you covered.
Dezod is offline   Reply With Quote
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 10:08 AM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 06:34 AM
wtb 1nzfe engine blown or working turboyaris Items for Sale by private party 5 04-08-2007 03:03 PM
Engine Management machine1 Performance Modifications 17 02-23-2007 12:26 AM
