Old 05-28-2007, 03:14 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
Acetone on Fuel save gas...
check it out "1/5000 to 1/3000" mixture of acetone and fuel gives you up to 27% more on miles/gal..
http://www.pureenergysystems.com/new...00069_Acetone/
i wonder if it does work???
Old 05-28-2007, 04:09 PM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Seems like a whole community is trying this out with positive results. Might be worth a try?
Old 05-28-2007, 04:15 PM   #3
drell42
Drives: Blank
MythBusters?!?
drell42 is offline   Reply With Quote
Old 05-28-2007, 05:18 PM   #4
marcus
toyota
marcus's Avatar
i have looked at myth buster and there is a conspiracy theory about it..
Old 05-28-2007, 05:26 PM   #5
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
Why are these articles over 2 years old???? Any followup??
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
Old 05-28-2007, 09:23 PM   #6
acetone will eat away at any rubber seals or plastics it gets in contact with. but yeah, you will get improved mileage, but your engine will fail much earlier. Your choice...
Old 05-29-2007, 12:41 AM   #7
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
I had a bad experience using acetone on our 04' 4-Runner. Coincidence? Possibly, but a blown head gasket at 26,000 miles shouldn't happen. I can't explain what happened, I just won't try it again. And yes, acetone will eat rubber and your paint if your not careful.
PetersRedYaris is offline   Reply With Quote
Old 05-29-2007, 01:23 PM   #8
jlift
Drives: 2007 Yaris Hatch
"I have soaked carburetor parts in acetone for months and even years to see if there is any deterioration. Any parts made to run with gasoline will work with acetone just fine. I presently have parts soaking in 1, 2, 5, and 10 % acetone/gasoline mixes as well as just gasoline. That is 20 to 200 times too much just to be sure. The 30R7 rated parts are in perfect condition. "
from website.
jlift is offline   Reply With Quote
Old 05-29-2007, 01:15 AM   #9
Yaris Omega
Finsh the Fight
Yaris Omega's Avatar
Drives: soon to be Yaris LB
werd
Yaris Omega is offline   Reply With Quote
Old 05-29-2007, 12:07 PM   #10
marcus
toyota
marcus's Avatar
ill use to pass emission someday...
Old 05-29-2007, 01:50 PM   #11
marcus
toyota
marcus's Avatar
yah but have you tried rubber and plastic parts... seals etc.. these are prone to acetone..but maybe not with such small amount of mixture..let me know.
Old 05-29-2007, 03:38 PM   #12
Creeper
Creeper's Avatar
Drives: Silver 2DLB Yaris
Send a message via AIM to Creeper
http://pesn.com/2005/04/12/6900080_Acetone_and_Ester/
that site has a bunch in info including engine wear and lub wear.
As for the o-ring and rubber peices here is a paragraph about it
"In early 2004, a SmartGas reader in New York State filled three bottles with: pure acetone, part acetone/part gasoline and straight gasoline. Into these he placed O-rings, pump diaphragms, plastic fittings, hose parts and other neoprene/n-buna stuff. He duped my experiments from back in the 50s. Months later he told me the pure acetone bottle was slightly darkened and some vinyl parts swelled. Dave had carefully marked all the parts beforehand. He dried the parts to mike them again and noted after six months that the growth was about two-percent to five-percent in the bottles with gasoline, which was well within limits. Almost unnoticeable. He put the stuff back into the respective bottles where it may still be today. Dave has a background in physics and engineering. I suggest testing parts as mentioned above, in 1, 2, 5, and 10 % mixes of gasoline and acetone. This is up to 200 times more concentrated than what we use in real life. No sense being ridiculous."
this paragraph was obtained from http://www.pureenergysystems.com/new...00069_Acetone/
Creeper is offline   Reply With Quote
Old 05-29-2007, 03:42 PM   #13
Creeper
Creeper's Avatar
also just found this at a different part of the same website
"Q. Has acetone ever harmed an engine?
No known instances reported that we know of in the fuel system.
*A note of extreme caution: Acetone is a very powerful solvent, and extremely corrosive to rubber. In fact, when the acetone hits a rubber fuel line, or o-rings, or any other rubber part coming into contact with the acetone, it will slowly be dissolved away. With continual corrosion of the rubber, it will eventually disintegrate, leading to extensive repairs of the fuel line, and a possibly worse if it happened while driving. When it all comes down to it, realize that you are using the acetone at your own consequence."
Seems a lot of the information on that website is very wishy-washy
Old 05-29-2007, 07:00 PM   #14
SailDesign
Drives: .
Did they test the parts with Acetone that had access to oxygen? i.e. in unsealed containers, like a part-empty gas-tank.
Thought not....
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 07:41 PM
branded (chevron) or generic (costco) gas?? static808 DIY / Maintenance / Service 55 11-28-2008 06:14 PM
Performance mods that won't affect/will hardly affect gas mileage?? Mr.Yaris Performance Modifications 15 07-30-2007 01:32 AM
I'd like to know this right now.. is brand name gas better for my new Yaris? fantabulousbaby General Yaris / Vitz Discussion 12 09-19-2006 10:14 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 09:07 AM
