![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
Water Leak in Boot
My poor car "Betty" seems to have sprung a leak. I noticed water collecting on the plastic trim panels behind the rear lights last year but it seemed to be fairly intermittent. Well its got worse to the point i've had to deal with it. It was soaking the carpet and the stuff in the boot.
I start disassembling everything, i suspected the rear light gaskets had perished and were leaking. I took them out and the weather strip off the roof and cleaned the mud and leafs out of everything but it was still leaking so i ripped out the plastic trim from the inside and had my dad spray the car with the hosepipe to try and find where it was leaking. ![]() ![]() I found water leaking from out of what seam but i couldn't see how it was getting in there in the first place. So i took the weather strip out and found this. ![]() ![]() Seems there was some stuff put in the seams under the boot seal but this stuff has perished or something. ![]() Doesn't look in great condition. Near as i can tell the water must have been finding its way under the seal and getting into the gap in the seam and then running down the inside. So has anyone had this before and what did you use to seal it up? Bog standard silicone sealer or did you use some proper seam sealer? I have heard sealing seams with water leaks on cars can be a bit of a pain.
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
2ZR swap. DO IT! Ask how!
I've recently found water stains below my tail light access panels, so I'm also interested in whatever fix is involved here. Might just be that the weather stripping is worn out and needs to be replaced? The metal inside the seal really only works once or twice, then is too loose to hold on properly.
#3 | |
Sent from my SM-G965F using Tapatalk
![]() Drives: Echo RS Join Date: Aug 2006
3 Yaris and counting..
Mine has been leaking for years. Can't find where it's getting in either. I'm getting water down the hatch side of your second pic. I've put Scilicone berms to redirect the pooling water into the spare tire well instead of working it's way to the back seat floor. I'll snap a pic later.
Well a little update on the water leak. I have made 2 attempts to fix it. First by sealing the seams underneath the weather strip and when that failed i put a slathered the outside of the weather strip with seam sealer to try and stop the water getting under it. This too has been a failure it still seems to be dripping in between two panels half way up where the boot.
Running out of ideas. I pulled more out and let the headliner down partially to try and see if i could see where the water is getting in by the metal panels obscure it from view. I can only try even more seem sealer next week when i can dry it out and pull it into my garage and try again. Running out of ideas and seem sealer. Honestly my frustration is getting to the point i'm two minds whether to take a sledge hammer to the fucking car at this point.
#7 | |
#8 | |
![]() Drives: Toyota Yaris 2007 1krfe Join Date: Sep 2023
Have you found the solution to this leak you have found? I have the same infiltration from where it comes to you... and I'm going crazy.. Thank you very much |
![]() Drives: '10 Hatchback Join Date: Dec 2016
Two suggestions. One for each leak path (under the weatherstrip, and between the weatherstrip and the liftgate).
1) Get some body seam sealer from an auto parts store. The black, tacky stuff. Similar to the black, tacky stuff you'll often find underneath a weatherstrip if you pull it off!! Remove the weatherstrip. Apply a bead of that sealer to the flange on the body that the weatherstrip pushes on to. Put it on the outside face of the flange, near the tip. Then when you push the weatherstrip back onto the flange it will smush this all up underneath it. The goal is for this to stop any water that gets under the weatherstrip from getting up and over the tip of the flange. 2) To increase the contact pressure between liftgate and weatherstrip, loosen the screws for the liftgate striker, shift the striker forward, then tighten them. Alternatively, hit the striker with a mallet to move it forward. Your liftgate will now latch in a "tighter" position, and compress the weatherstrip more. Just note that it will require more force to get it to close. |
| 2008 toyota yaris 2 door hatchback water leak | knobby bobby | DIY / Maintenance / Service | 8 | 07-03-2024 06:42 AM |
| Water in the boot | BartSimpson | DIY / Maintenance / Service | 8 | 03-24-2019 04:23 PM |
| 09 Yaris Rear Water (rain) Leak | Loki452 | DIY / Maintenance / Service | 14 | 03-02-2019 07:35 PM |
| 08 Yaris water leak troubleshooting help requested | 2bz | DIY / Maintenance / Service | 5 | 12-22-2018 05:37 PM |
| Water Leak! Failed Relays | cfeng | DIY / Maintenance / Service | 0 | 12-13-2010 05:21 AM |
