![]() ![]() Drives: Yaris 2008 Sedan Join Date: Nov 2010
"Damper" on transmission mount, what does it do?
Part number 12351-21090 https://www.toyotapartsdirect.ca/ima...ze/113752L.jpg
Labeled 12351 at the bottom right in that image. It is attached to the back of the transmission mount bracket. I'm caving in and buying all four main motor mount components from toyotapartsdeal to see if this will get rid of my engine vibration issue. I was curious if anyone is familiar with this component and its function. From my visual inspection, it does not seem to do anything. It is called a damper, and I assume it dampens as a weight somehow, but it just seems to be a piece of rubber? Just wanted to see if anyone has anything on this before I go take everything apart so I can take a closer look at it. |
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
Was looking at that piece on Sunday whilst installing my engine/trans thinking the same thing... what's this things purpose?
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
| 06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) | 06YarisRS | Performance Modifications | 448 | 12-06-2018 08:12 PM |
| wtb transmission mount | str8Yaris | Willing to Buy by private party | 0 | 06-04-2011 09:59 AM |
| DIY Camera Mount -- No Cost Version | KCALB SIRAY | DIY / Maintenance / Service | 20 | 06-08-2009 03:12 PM |
