Old 05-02-2009, 11:18 AM   #37
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Thats what an auto forum is all about,thanks CTScott
Old 05-02-2009, 11:55 AM   #38
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
learning
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 05-02-2009, 12:02 PM   #39
momerath
Drives: '09 Yaris 2 door liftback
Hello. I'm eager to try this out next week. I just have a couple of questions.
Question #1:
You stated in step 6: "Connect wires from switch assembly to wires on connector D3. Red wire from switches connects to blue wire of D3 Pin 1. Black wire from switches connects to brown wire of D3 Pin 3."
It's unclear whether or not I connect the switch assembly wires to the blue/brown wires themselves or to the connectors. The picture isn't clear because I'm not seeing the added black and red switch assembly wires. Is the picture under step 6 a before or after? It is exactly the same as the picture under step 3.
Question #2:
How do you remove the "push button start" cover? I tried playing with it to see if I could snap it off but I had no luck. It seems pretty firmly in place. I didn't want to force it too much for fear of breaking it off.
Question #3:
How easy is it to run the wire from that cover to the steering wheel assembly? Is there a direct path from the cover into the assembly?
thanks!
momerath is offline   Reply With Quote
Old 05-02-2009, 12:35 PM   #40
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
TDB-1, to jump the switch connector, you simply put a wire from one terminal to the other (the switch plug only has 2 terminals right)? You didn't put a fuse or anything in there just in case?
My Car Rules!
nickhjort is offline   Reply With Quote
Old 05-02-2009, 01:34 PM   #41
TDB-1
Drives: 09 3-door 5speed
Correct, I actually used a small spade terminal and just pushed it into the connector. Just don't step on the clutch when using cruise!!!! I have not hit the clutch but think if you did it would rev the motor till the computer or rev limiter figures out what is happening.
TDB-1 is offline   Reply With Quote
Old 05-02-2009, 02:29 PM   #42
nickhjort
nickhjort's Avatar
Gotcha. Thanks again man! And of course thanks to all the smart people who know how to do this stuff and make it easier for us dumb people to DIY :) I'm going outside right now to set this push-button system up. I'll let you know how it goes.
My Car Rules!
Old 05-02-2009, 05:59 PM   #43
Answers in red below:
Question #1:
Picture 3 and 6 are actually the same "after picture". The red tap-splices are how I connected my red and black wires to the brown and blue wires.
Question #2:
You have to pull the black vertical trim along side of the AC controls / radio (just get your fingers under the edge and pull it out). Once that is removed the cover pulls right off.
Question #3:
Very easy - When you come through the back of that hole you loop to the left and right up along the wiring harness for the steering column.
thanks!
Old 05-02-2009, 06:47 PM   #44
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Wow... this is really really cool. I'm pretty sure I don't have the LEDs on the dash, but I don't mind adding some in the same panel as the buttons.
Excellent job, Scott and Pavel!
Old 05-02-2009, 11:46 PM   #45
d1nzfe
Drives: 1NZ-FE
anyone tried on the sedan yet?
d1nzfe is offline   Reply With Quote
Old 05-04-2009, 09:26 PM   #46
mariann
Drives: yaris 2007
any one knows if the 2007 model come ready to install cruise controll? (its the same model as 2009)
mariann is offline   Reply With Quote
Old 05-04-2009, 10:41 PM   #47
mariann
Drives: yaris 2007
did you read the Can we do this thread
ofcorse. but i go tired on page 4. and skipped to the last pages.
havent found any info about it.
by the way. just now i looked in the 2007 manual - cruise controll. and its exactly as described. also has the plugs as shown. the same wires. and need the same resistors.
i think it will work the same as my dealer said: "its exactly the same vehicle. 2007 2008 2009 no changes what so ever" he was right.
the post is for AT and MT... but here we have only Robotic Transmission... so i think i'll consider robotic transmission as an automatic transmission... hope it will work.
any advice guys?
Old 05-04-2009, 11:05 PM   #48
any advice guys?
Does your 07 have the brown and blue wires in the D3 connector?
Also, does it have the cruise indicator on the combination meter?
If it doesn't have the D3 wires, then it will require the work that nickhjort did on page 16 of the other thread. Once all of the trial and error is sorted out in the other thread we'll put together a DIY for Yaris which need the additional work.
Old 05-05-2009, 04:26 AM   #49
regal
Drives: 09 Yaris 3 Dr White LB
very cool, but is there a tutorial for thos of us who want to you the OEM stock to keep it stock looking? Sounds a much better way to go that the $220 aftermarket option.
regal is offline   Reply With Quote
Old 05-05-2009, 06:39 AM   #50
suiller
Drives: Yaris Sol 1.3 dual VVTi 101hp
above all can we do on 2009 model??
Yaris Sol 1.33 dual VVTi model 09 - 5dr
1. full ZX1 additive treatment: oil + cooler + fuel
2. NB treatment: motor oil
3. K&N panel air filter (part num. 33-2211)
4. Fuchs Silkolene Pro SRG 75 gear oil (the best!)
5. UltraRacing 19mm rear sway bar
suiller is offline   Reply With Quote
Old 05-05-2009, 10:00 AM   #51
A couple of people have purchased OEM stalks and will be installing them. Hopefully one will document the process for those interested.
Old 05-05-2009, 10:02 AM   #52
I don't have the electrical wiring diagrams for the European Yaris to verify that all is the same as for our USDM ones.
Old 05-05-2009, 10:05 AM   #53
mariann
Drives: yaris 2007
well. this is ehat i have.
thats my D3 connector. i'm sure its the right one because is tried to honk after disconnecting it.
i do have a brown and blue wire but seems they are not in the mentiond above terminals. or is it?
click on the images to see in supersize
and there are somepictures of the display. i couldent find the cruise controll light or set light. maybe you'll find.
i did manage to pull out the A21 connector to see if there is the specific wire inside but got stuck with the L shape plastic wich cover the wires? there is a way to pull it out without breking it?
help please
Old 05-05-2009, 10:40 AM   #54
nickhjort
nickhjort's Avatar
mariann,
It's pretty straight forward. Just cut the ziptie at the top of the cover VERY CARFULLY! Do not cut any of the wires, obviously, or you will be SOL big time. After cutting the ziptie, there are two clips on the left side of the cover. push them in and lift. Then you will see two hooks on the back of the cover, life the cover and pull so that hooks release. And to reinstall the cover just do the opposite. You will have to have a ziptie to replace the one you cut. If you don't have a ziptie, the clips and hooks will hold the cover in place, but the wires undernieth will be hanging loose. Here's some pics...hope they help.
My Car Rules!
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
