#37 |
#38 |
I have had this code before with the stock setup so i am not to concerned.
#39 | |
![]() ![]() Drives: Toyota Join Date: Mar 2010
Now still monitoring what causes this CEL.
#40 |
![]() Drives: Yaris Sedan Join Date: Jun 2010
i got a TB with part number #22030-0D030 and want to install it next week.
should i do chip swap and idle screw adjustment? and what about coolant bypass?
|Blitz S/C|aFe Intake|NST SSK|NST Busing kit|Ralco Short Shifter|Dastek Unichip type Q|Dastek Throttle Control|1ZZ Injectors|1ZZ TB|Custom Header|Custom Exhaust|Head Porting|Momo Drifting Steering wheel|Momo shiftknob|Denso Irridium Sparks|Buddy Club P1 Racing Wheels|195/50/R15|Tanabe NF Coilover|Goodrich SS brake lines|Ultra Racing Front Strutbar|NRG Grounding kit|Custom Grill|Custom Eyelid|Rear Sway bar| |
#41 | |
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
I didn't do the coolant bypass because it can get pretty cold where I live and I don't want any issues. Car works awesome with it hooked up. |
#42 |
Hi Guys,
I had swapped my 1NZFE chip into the 1ZZFE throttle body but after one day of driving... CEL light up.. error code 0172 (fuel trim too rich bank 1) I reset my ecu, and drove again... and the next day... the same error code came out.... ![]() These two codes came when i was moving off slowly and with air con on. I swapped the 1ZZFE chip (part number #22030-0D030) back onto the throttle body and there's no CEL till now. But i could feel rpm oscillations when car was slowing down. By adjusting the idling screw, does it helps to remove the oscillations? Should i stick to 1ZZFE chip or try making the 1NZFE chip works? ![]() Thanks everyone!
#43 |
Any advice, please?
Thanks...
#44 |
Leave the 1NZ chip in. That's the way I have it and it works great.
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
#45 |
#46 |
Sorry, I meant to say to leave the 1NZ chip on the 1ZZ TB. I made the swap and I haven't had any issues so far, other that a high idle when cold starting the car.
On the other hand, I've heard from some people that didn't need to swap the chip at all (1zz chip on 1zz TB). I have a theory that the issue is directly related to the TB serial number, but I can't say for sure. I tried compiling a list of serials a few months ago, but it didn't catch on.
#47 | |
![]() With your 1NZ chip on the 1ZZ TB, did you experience any jerking (around 1300rpm) while you were driving? Did you adjust your idling screw? How many turns did you adjust? Anti-clockwise? Thanks in advance, tk-421...
#48 |
Still running great no CEL.
#49 | ||
Don't mention it.
#50 | |
#51 |
![]() Drives: YARIS Join Date: Sep 2010
i have scion tc tb in my yaris
#52 |
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
#53 |
wow thread back from the dead. anyway may car is still running great no cel just a little high idle in the winter months but it is all good.
| 1ZZ-FE throttle body | crxgames | Items for Sale by private party | 1 | 04-27-2009 05:19 PM |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 08:52 PM |
| DIY: Tricking ECU Throttle Body Relearning | gwasabi | DIY / Maintenance / Service | 2 | 04-03-2009 07:02 PM |
| Toyota Throttle Body Spacer: the Best Fuel-Saving Device | davidmills | Performance Modifications | 1 | 07-01-2007 11:38 PM |
