![]() ![]() Drives: BMW 3 Series M Sport Join Date: Jan 2011
Wheel Spacers
Hi, i have done a search and read some of the topics on wheel spacers but want to double check before buying
What mm can i go to before having to change the wheel bolts? im going for 5mm on the front and was think 10mm on the rear. Will these be ok? http://www.performancealloys.com/spa...ls.aspx?ID=191 All the spacer for sale for my model of yaris http://www.performancealloys.com/all...PCDID=33&tab=3 Any help will be appreciated
You can get away with stock studs for 5mm (though I'm not recommending it). 10mm will require longer studs.
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
if your'e doing the 10mm inthe rear why not do the penguin spacer back there and not between the rim and drum.
the penguin spacer goes behind the backing plate. can be installed permanently in less than 30 minutes (assuming you inow what you're doing...), and dont damage/threaten the studs in any way. you can even go 13mm if you want |
#5 | |
Ok, Penguin it is.
Just sent an email to micro image for shipping cost to the uk Thanks for you help guys Last edited by Nips; 01-30-2011 at 05:00 AM. |
I'm now thinking of getting 10mm Ichiba Wheel Spacers for the front and 13mm penguins for the rear would this be a good set up for standard 17" SR wheels without any rubbing or catching?
^ this depends on the offset of the wheel and the tire being used, and also camber. A little negative camber goes a long way to eliminate rubbing (and improves handling too!).
It may be necessary to trim some fender liner away in spots to eliminate any rubbing.
#9 | |
Ok thanks for your advise, but as a set up 10mm at the front and 13mm at the rear is this a good starting point? the wheels are 215/45/r17 not sure what the offset is Thanks |
Not withstanding the critical offset number, here is one thing to keep in mind.
Installing 10 to 13mm spacers in the back will bring the rear wheels more inline with the fronts. Installing 10mm in the front will continue to push the wheels out further than the rear. If you are looking for cosmetic symmetry front to rear, then I would not put anything on the front. What is your ultimate goal?
#11 | |
Lowered every previous car i have owned and don't want a back breaking ride, plus UK roads are shit compared with US roads from what i've seen |
How would i find/work out the offset?
^ you can either look up the wheel online, or it might be cast into the back of the wheel.
Or you can post a few pics of what it looks like now, so we can all comment, discuss, and nitpick the whole thing -- which is great for you.
#14 |
#15 |
I've got 215/35/18 with a 42(or maybe 45) offset and I installed the 10mm Penguin spacers on the rear. No spacers on the front. Looks great!
#16 | |
Just awaiting a reply from micro image, i think i will order 13mm peguins for the rear and leave the front standard |
#17 |
![]() ![]() ![]() ![]() ![]() Drives: it is kinda stock Join Date: Oct 2010
yeah do you have pics altitude i was thinking about this mod as well
#18 |
![]() ![]() Drives: Blazin' Blue 2007 Yaris LB Join Date: Sep 2011
What spacers would you reccomed for the stock 15's?
| 25 mm Wheel spacers | Rnankoo | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 24 | 03-22-2011 08:58 PM |
| Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed | RedVitz | Photo-Video-Media Gallery | 18 | 10-09-2010 04:36 PM |
| Installed 10mm PG spacers on a 15x7 +25 wheel | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 08-27-2009 08:10 PM |
| Steering Wheel Spacers? | BassAssassin | Cosmetic Modifications (Exterior/Interior) | 0 | 08-12-2009 01:52 PM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 09:30 PM |
