Old 07-02-2010, 03:12 PM   #37
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Originally Posted by kou View Post
So its has been a week and still going great.One cel/code popped up which was a p0171(bank 1 system lean.)This only happened once on a 95degree day with high humidity the AC on stuck in traffic,cel turned off on it's own the next day so i am sure its because of the conditions that day caused the cel.
Did you do a coolant line bypass on the 1ZZ TB? I did, and I've literally never had a CEL with my TB.
Although it may not be advisable under very cold weather for what I hear (we don't get too many of those down here)...
Old 07-02-2010, 03:15 PM   #38
kou
Drives: 08 lb
Yes i did,i am thinking about putting it back in the fall.
Old 07-02-2010, 03:17 PM   #39
kou
Drives: 08 lb
I have had this code before with the stock setup so i am not to concerned.
Old 07-03-2010, 07:17 AM   #40
sito
Drives: Toyota
So its has been a week and still going great.One cel/code popped up which was a p0171(bank 1 system lean.)This only happened once on a 95degree day with high humidity the AC on stuck in traffic,cel turned off on it's own the next day so i am sure its because of the conditions that day caused the cel.High humidity not good.
Kou, i also have the same symptom as yours. AC on, stuck in traffic, CEL on. But my error is p0172(bank 1 rich). CEL went off on its own on the next day.
Now still monitoring what causes this CEL.
sito is offline   Reply With Quote
Old 07-03-2010, 11:43 PM   #41
moh
moh's Avatar
Drives: Yaris Sedan
i got a TB with part number #22030-0D030 and want to install it next week.
should i do chip swap and idle screw adjustment? and what about coolant bypass?
|Blitz S/C|aFe Intake|NST SSK|NST Busing kit|Ralco Short Shifter|Dastek Unichip type Q|Dastek Throttle Control|1ZZ Injectors|1ZZ TB|Custom Header|Custom Exhaust|Head Porting|Momo Drifting Steering wheel|Momo shiftknob|Denso Irridium Sparks|Buddy Club P1 Racing Wheels|195/50/R15|Tanabe NF Coilover|Goodrich SS brake lines|Ultra Racing Front Strutbar|NRG Grounding kit|Custom Grill|Custom Eyelid|Rear Sway bar|
moh is offline   Reply With Quote
Old 07-04-2010, 12:02 AM   #42
Astroman
Modded Moderator
Astroman's Avatar
Just try swapping over first like I did. Didn't need to do a chip swap or idle screw adjustment.
I didn't do the coolant bypass because it can get pretty cold where I live and I don't want any issues. Car works awesome with it hooked up.
Old 07-08-2010, 06:45 AM   #43
sito
Drives: Toyota
Hi Guys,
I had swapped my 1NZFE chip into the 1ZZFE throttle body but after one day of driving... CEL light up.. error code 0172 (fuel trim too rich bank 1)
I reset my ecu, and drove again... and the next day... the same error code came out....
These two codes came when i was moving off slowly and with air con on.
I swapped the 1ZZFE chip (part number #22030-0D030) back onto the throttle body and there's no CEL till now. But i could feel rpm oscillations when car was slowing down. By adjusting the idling screw, does it helps to remove the oscillations?
Should i stick to 1ZZFE chip or try making the 1NZFE chip works?
Thanks everyone!
Old 07-09-2010, 12:01 AM   #44
sito
Drives: Toyota
Any advice, please?
Thanks...
Old 07-09-2010, 02:25 AM   #45
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Leave the 1NZ chip in. That's the way I have it and it works great.
Old 07-09-2010, 05:49 AM   #46
sito
Drives: Toyota
Leave the 1ZZ chip in. That's the way I have it and it works great.
Thanks for your advice, tk-421.
Are you using the 1ZZFE chip with the 1ZZFE throttle body too?
Thanks....
Old 07-09-2010, 02:23 PM   #47
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Sorry, I meant to say to leave the 1NZ chip on the 1ZZ TB. I made the swap and I haven't had any issues so far, other that a high idle when cold starting the car.
On the other hand, I've heard from some people that didn't need to swap the chip at all (1zz chip on 1zz TB). I have a theory that the issue is directly related to the TB serial number, but I can't say for sure. I tried compiling a list of serials a few months ago, but it didn't catch on.
Old 07-09-2010, 02:44 PM   #48
sito
Drives: Toyota
Thanks for the advice,tk-421...
With your 1NZ chip on the 1ZZ TB, did you experience any jerking (around 1300rpm) while you were driving?
Did you adjust your idling screw? How many turns did you adjust? Anti-clockwise?
Thanks in advance, tk-421...
Old 07-16-2010, 03:43 PM   #49
kou
Drives: 08 lb
Still running great no CEL.
Old 07-17-2010, 03:39 AM   #50
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Don't mention it.
The bigger TB will increase your overall throttle response. There's a bit on an adjustment required on your part (basically, one needs to be less hard on the pedal). Although to be honest, the throttle controller that I have installed makes that effect much more apparent.
I can't remember right now, but I believe it was more to the right (CW) than the left (CCW), but it really should depend on your particular installation. You can adjust it while the engine is on, but don't trust it too much... The ECU will also try to auto-adjust over the next few days. If you don't feel that it's perfect you can always try adjusting it further. Just be careful not to strip the screw!
Old 07-26-2010, 08:53 AM   #51
sito
Drives: Toyota
Don't mention it.
Thanks for the advice, tk-421....
Old 01-31-2011, 08:43 PM   #52
IVAN_TRD
Drives: YARIS
i have scion tc tb in my yaris
IVAN_TRD is offline   Reply With Quote
Old 02-01-2011, 10:32 AM   #53
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
is it from a Z or R motor???
Old 02-01-2011, 05:01 PM   #54
kou
Drives: 08 lb
wow thread back from the dead. anyway may car is still running great no cel just a little high idle in the winter months but it is all good.
Cleaning throttle body ToTo Performance Modifications 18 07-27-2011 06:20 PM
1ZZ-FE throttle body crxgames Items for Sale by private party 1 04-27-2009 06:19 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 09:52 PM
DIY: Tricking ECU Throttle Body Relearning gwasabi DIY / Maintenance / Service 2 04-03-2009 08:02 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-02-2007 12:38 AM
