Old 01-26-2012, 12:15 AM   #19
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
I've been wanting to get rid of some of that road noise that tends to plague the Yaris, but I don't want to add a ton of weight to the car with sound deadening.
I think this might be my solution.
You think if I just do the wheel wells then it will make a difference? I probably won't be able to get to the underside of the car due to my lack of a lift.
Black_griffin6 is offline   Reply With Quote
Old 01-26-2012, 12:47 AM   #20
SAV912
Pirate Yaaaaris
SAV912's Avatar
Not to burst your bubble, but you are incorrect. I can attest to that easily. 50lbs is 50lbs and will affect acceleration and braking. I see a very noticeable difference rolling on 15s as opposed to my 18s as well as whether or not I have my subwoofer box in the trunk or do not. Performing a spare tire delete even makes a difference. Every change you make to a car that is designed like the Yaris has an impact and you need to weigh the pros/cons. An example is going boosted and not only that, but whether or not you go SC or turbo when you gauge your FE. You very well trade FE for power.
Unsprung weight =/= dead weight. There will be a noticable difference on weight attached to parts of the car that directly handle the power vs weight somewhere else in the vehicle. That's why lighter wheels and tires are more noticable than removing the spare tire or a subwoofer.
But if you notice 50 lbs (which must be a hell of a hard hitting woofer), then more power to you. My butt dyno isn't that sensitive.
Scott, I'm thoroughly envious of your lift. And I may do the rubber brush on coating now. I've already done spray on bedliner and it made an appreciable difference, but I only did two coats on the wheel wells. I didn't do anything under the center of the car.
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 01-26-2012, 04:09 AM   #21
henrylee
henrylee's Avatar
Drives: 2011 Yaris Sedan Red Power pkg
So jealous of your garage!!! Money well spent
SOLD: 2011 Yaris Sedan ll Barcelona Red ll Auto ll Power Pkg ll Scion 7 spoke Wheels ll Llumar tint ll "S" Body Kit
http://www.yarisworld.com/forums/showthread.php?t=38682
henrylee is offline   Reply With Quote
Old 01-26-2012, 11:56 AM   #22
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
wow 50 lbs will slow you down guess mine must really be slow then but i cant hear anyone honking at me with the quitness i have in mine i will take the extra weight over road noise any day that is a clean under coat job i have thaught about doing that myself some day
pennyracer is offline   Reply With Quote
Old 01-26-2012, 02:38 PM   #23
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
not to hijack the thread, but all I can say is that when I went and did my LSRs I noticed a difference with certain things removed.
Scott, great idea. I might have to do it myself when I have my body work done.
Old 01-26-2012, 04:06 PM   #24
josh044
Drives: 07 yaris hb - 5 spd
Pennyracer - how much time did all that sound deadening work take?
josh044 is offline   Reply With Quote
Old 01-26-2012, 04:57 PM   #25
pennyracer
boydstir
pennyracer's Avatar
oh there is hours of work there not sure lost count that was the first layer i have 2 layers down and the roof is the same but i added dynamat foam layer also to make sure its nice and tight for the sound system i have in my lb :) never can go wrong with any sound deadening work to the yaris they need all you can give them
Old 01-27-2012, 01:27 AM   #26
SAV912
Pirate Yaaaaris
SAV912's Avatar
Holy crap, Penny. That's looks like a few hundred bucks in sound deadening. I've done truck bed liner on the spare tire floor but that's it. I really want to Dynamat the interior like that but time is a factor. I generally don't have enough days off lined up to tear stuff apart and lay it all down and put it back together.
-C
Georgia Bulldogs!
Old 04-10-2012, 01:51 AM   #27
Spidermandud
Spidermandud's Avatar
Drives: Black '08 Yaris Hatch S
Did the CtScott Special over the weekend; lovin it!
-Will-
Spidermandud is offline   Reply With Quote
Old 04-10-2012, 04:29 PM   #28
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Would this stuff be the same?
http://www.canadiantire.ca/AST/brows....jsp?locale=en
Dupli-Color Bed Armor Truck Bed Liner if you can't see the link.
Also, did you have to sand the paint in the wheel well or did you just clean + paint?
devinlamothe is offline   Reply With Quote
Old 04-10-2012, 04:34 PM   #29
That's the same stuff. The kit is more expensive, since it includes a roller, etc.
I didn't sand, but rather just cleaned very well using simple green and painted.
Old 04-10-2012, 05:29 PM   #30
devinlamothe
Awesome thanks. I am going to do this when it's nicer out to help prevent rock/salt damage. Thanks for the idea and the pics
Old 12-30-2012, 03:48 AM   #31
birdman
Drives: '08 Blazing Blue Yaris LB
That undercoating looks do-able even for me. The road noise on grainy pavement is tiresome alright. When you get the stuff on you how do you get it off?
birdman is offline   Reply With Quote
Old 12-30-2012, 08:32 AM   #32
Ideally you don't get it on you. Acetone works somewhat for getting it off skin. If you don't slather it on too thick it won't drip.
Old 12-30-2012, 03:16 PM   #33
MyzticZ3r0
Drives: 2007 Toyota Yaris Hatchback
That lift works wonder for you! It looks great and I'm glad to hear road noise is cut down. Thanks for the awesome photos as well!
MyzticZ3r0 is offline   Reply With Quote
Old 02-06-2013, 03:28 AM   #34
Driftw00d
Clueless
Drives: 2008 Toyota Yaris "Bayou Blue"
Does it come off easy if you want to take off the bolts underneath there?
Driftw00d is offline   Reply With Quote
Old 02-06-2013, 07:58 AM   #35
It really doesn't come off, but bolts break loose without a problem.
Old 02-07-2013, 05:22 PM   #36
nookandcrannycar
Performing a spare tire delete even makes a difference. .
Good to know. For everyday driving (unless going away on a trip), I'm going to remove mine. I have tire sealant and am paying extra for AAA plus coverage (longer free towing range). I've never needed either within my metro, but they'd be available if need be. Normally painless and transparent ways to increase MPG = all good in my book. I just thought (not based on more than a vague hunch really) removing it wouldn't make any difference. I trust your judgement. I don't think you would write this unless you had noticed a difference (even if it isn't much). Come to think of it, I can't remember the last time I had to put the spare to use in a car.
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 03:14 AM
Sound dampening rear hatch area? m911gt DIY / Maintenance / Service 28 10-10-2013 04:39 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-05-2011 12:56 AM
Just ordered some sound dampening stuff Brad D General Yaris / Vitz Discussion 8 06-10-2009 09:09 PM
Any non-Dynamat sound dampening? vodkalush In Car Entertainment + Electronics (audio / video / alarm) 12 11-18-2006 03:32 AM
