Old 03-09-2014, 03:27 PM   #253
nookandcrannycar
3/9/14 - Today: AutoZone - Sylvania Halogen Bulb -$11.90 (10.99 + 91c Tax) for failed driver's side low beam (high beams on both driver's side and passenger side are the 7+ year old factory originals). IIRC, when I replaced the last one, I compared this cost to the OEM Toyota bulb at a dealer....and the OEM bulb was almost 4 x as much.
3/9/14 - Today - 275,441 miles:
Toyota dealer installed the Sylvania Halogen Headlight Bulb (service open 9-2), didn't charge me.
Old 03-09-2014, 03:48 PM   #254
nookandcrannycar
P.S. : Scratch the 'High Beams are the originals' -- CTScott pointed out on BeefJerky's 'Headlights Out' thread today that the Yaris headlight bulb = 1 Dual Beam (both high and low) bulb.
Old 03-09-2014, 03:53 PM   #255
nookandcrannycar
^^^^^ I was attempting to edit post #253 (added the P.S.), and somehow it came out as a new post (I DIDN'T type the body of the post a 2nd time).
....Aha...I forgot to log in BEFORE going to the page.
Old 03-09-2014, 04:06 PM   #256
MyzticZ3r0
I asked the guys at my local O Reilys to install my headlights. My hand is just too big to fit behind the driver side unit :-/
MyzticZ3r0 is offline   Reply With Quote
Old 03-09-2014, 09:01 PM   #257
nookandcrannycar
Same thing with the Toyota tech today in the service drive up, trying to reach that little clip...so he pulled the car inside foir a minute and took the headlight off. My hand is too big as well.
Old 03-15-2014, 03:20 PM   #258
randeez
Drives: 2008 3dr
Originally Posted by randeez View Post
5 months and 20,000 miles
just shy of 50,000 miles now, couple of syn oil changes, replacing air filter, changed plugs (no difference), still have a low idle stumble every once and a while. just rotated tires and checked brakes front/rear. finally got a ultragauge- the lack of gauges in the base model leaves mea bit worried. have it set up for instant mpg, average mpg, tach, water temp, voltage, and miles till empty- going to see if i can find oil pressure though
been a little while, had to jump on and order some stuff from Garm(microimage)
brakes are getting a little noisy, passenger side pad, although still having more then 50% material left, looks like it has some stress cracking and pedal feel sucks - ordered new rotors and pads, going to flush all the fluid out as well
for future use:
11/5/11 @ 32,500 (purchased shortly before)
4/12/12 @ 50,000
3/15/14 @ 123,494
randeez is offline   Reply With Quote
Old 03-18-2014, 10:32 AM   #259
pop pop
'09 Sedan
Drives: '09 Yaris sedan
Originally Posted by pop pop View Post
Got a 2009 sedan/auto with 87,000+miles and climbing. Water pump went south @ 75,000, but overall, a great little car.
I hit the 100,000 mile mark on 2/16. Hope to put another 100,000 in the coming years.
pop pop is offline   Reply With Quote
Old 03-29-2014, 04:36 PM   #260
nookandcrannycar
3/29/14 -- I thought my first air filter change was at 131,000 + miles, but I noticed in my log book that the first change was at 74,000 + miles. Given this, I'm now somewhat around 'my average' re miles on a filter (replaced at 74k +, 131k + and 208k +)....so I'll probably buy a new air filter next week (now closed for the rest of the weekend, IIRC) at a Toyota dealer and swap it with the old one.
Old 03-29-2014, 05:05 PM   #261
MyzticZ3r0
=O I change my air filter + cabin air filter every year! I could probably change my cabin air filter later, but I just don't want any smells in my air.
Old 03-29-2014, 08:02 PM   #262
yougojay
25, 550 MILES!
Drives: Yaris L Coupe
2013 Yaris L 4 Speed Automatic Absolutely RED - Built 09/12 Purchased 4/11/2013 - 6,347 miles today - Zero problems Thank You Yar Yar
yougojay is offline   Reply With Quote
Old 03-29-2014, 09:05 PM   #263
Kal-El
Kal-El's Avatar
Expect 100,000 miles with zero problems. 200,000 miles with just a few repairs. And a few other maintenance items through 300,000.
Old 03-30-2014, 12:51 AM   #264
nookandcrannycar
Yep!
Old 03-31-2014, 10:51 AM   #265
randeez
Drives: 2008 3dr
for future use:
4/12/12 @ 50,000
3/15/14 @ 123,494
124,818 front pads/rotors and brake fluid
pads still had plenty of material, honestly think I could have gone 200k miles with oem pads- they were just breaking away from the steel backing maybe not broke in properly?
discs could have been reused/turned and reused for sure but I wasn't positive what was causing brake shake so I ordered some r1 rotors and hawk pads from micro image.
rear brakes I changed awhile ago, upon the advice of tire dick around 100k miles . I looked at them before and they didn't have much material... when he mentioned it I figured mileage had been plenty for oem to change anyway. Went ahead and ordered new ones, made the time to change em, pulled the drum off and realized they just don't have much material on them to begin with. But I had new shoes and the time to do it.
btw they quoted me almost 300bux to service rear brakes, so check em yourself they only have maybe 1/8"-3/16" of material
Old 04-13-2014, 12:16 AM   #266
nookandcrannycar
I was flipping the radio dial early this afternon and happened upon a local car maintenance show in the middle of a call. I didn't hear what type of car it was or what was wrong (that came before I tuned in). I did hear that she had purchased the car used with 69k miles on it (which they later said was very low for that car for that model year). One of the hosts asked if the car had been sitting outside for a long time. She said it had. The most experienced host said the air filter may need to be changed. He said (in the thickest local accent you can imagine) if that doesn't work then the impediment might be "a varmint's nest" . I just about fell over laughing. So authentically himself...and knows his stuff. I truly love this state . This little slice of life reminded me that I decided a couple of weeks ago to (in the near future) change the air filter in my Yaris. I stopped by Fred Haas Toyota later in the day (filter was under $22 including tax...same price as the last one, IIRC). So.....
at 277,668 miles ---- Installed new air filter (cost to install = zero....I didn't charge myself )
Old 04-13-2014, 09:30 AM   #267
yougojay
25, 550 MILES!
Yes, Thank you - It still amazes me in regards to the mileage some people here have put on their Yaris' . Just had the 2nd freebie oil change yesterday morning at 6,524 miles, 1 year & 1 day since delivery. Was driving home and noticed the little next oil change due sticky, 11,524...It actually startled me (don't laugh at me Nook, I'm tellin' ya, DON'T laugh!) Oh yeah I'm thinking, 5,000 miles or 6 months....I'll have 11,500 on the ODO in a few years!
I am just so happy with this 'Lil Car, it makes complete sense to own.
Old 04-13-2014, 09:14 PM   #268
nookandcrannycar
I agree. I'm amazed that our little model doesn't have a wider following it the United States.
Old 04-13-2014, 11:25 PM   #269
trunkout
4 years of P90X!
Drives: 09 Yaris Sedan
yikes...
I just found out.... at 97k.... I had no cabin filter..... so gross.....
trunkout is offline   Reply With Quote
Old 04-13-2014, 11:32 PM   #270
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
sent from my m-o-b-i-l-e
excessive sulfur odor on 2007 model year Yaris tomjasz General Yaris / Vitz Discussion 121 03-13-2010 06:49 PM
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
