Old 01-03-2020, 10:46 AM   #199
myfirstyota
3 Yaris and counting..
If you were closer I'd sell you my exhaust from my red car.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 01-03-2020, 10:50 AM   #200
Maritime
Drives: 2008 yaris 5dr hatch
Thanks, shipping would make it to expensive but appreciate the offer. I already had to replace the muffler about 2 months ago and that took $ away from the tires. I will get them eventually as the set on it will die, but I can't replace good tires so it will be when $ are there or tires are done.
Maritime is offline   Reply With Quote
Old 01-04-2020, 08:27 AM   #201
logoris
Drives: 2017 Yaris SE Blue Streak
Saw it on the 115 on New Years Day, looks awesome.
I was surprised to see how stable it was,
logoris is offline   Reply With Quote
Old 01-04-2020, 08:37 AM   #202
How solid is it? I'm in need.
Old 01-04-2020, 09:38 AM   #203
myfirstyota
The manifold end is good. The muffler end, not so much.
Comes with o2 sensor cause I cant be bothered to remove it
Old 01-04-2020, 09:40 AM   #204
myfirstyota
It's very stable. It rides like it should and corners, I think, better than stock.
5"wider stance in the front and almost 6" wider in the rear
Old 01-04-2020, 09:55 AM   #205
Damn. Same story with my existing components.
Old 01-04-2020, 09:57 AM   #206
myfirstyota
It's still in one piece, it's just the lip that holds the gasket in place. I'm going out to the shed later, I'll check it out and take a pic. You can be the judge
Old 01-04-2020, 11:44 AM   #207
logoris
i would have thought with the taller tires it would feel not as planted compared to the factory tires. on my rabbit i had a 4" lift on bilstiens, i found the suspension firm but when turning or highway speeds it tended to wander abit due to the higher side wall
Old 01-04-2020, 02:26 PM   #208
myfirstyota
It does wander a bit. But as you said, any high profile sidewall will cause that.
Old 01-04-2020, 02:29 PM   #209
myfirstyota
Sorry buddy. The flange that holds the muffler gasket in place is completely rotted away.
Old 01-04-2020, 03:08 PM   #210
Damn again!
Old 01-23-2020, 08:27 PM   #211
justjesus
justjesus's Avatar
Drives: 2008 Liftback
I was smiling almost the entire time I was catching up on the last few pages of this thread
:) big smiling :D
Applause, for you, sir! That looks great!
Old 03-03-2020, 03:02 PM   #212
myfirstyota
So, I was wondering...
Is there any general interest in this lift kit?
I was considering putting a few of these kits together for sale.
Things to keep in mind:
- You will be on your own for tire/rim fitment. Because of the design, the oem rim offset will not clear the front lift plates. Rim spacers and/or different rim offset is required.
- You will need to source your own steering shaft boot. There just aren't that many early 2000's ford ranger shift boots in the local scrap yard. (That's what I used)
- I can not guarantee front spacer plate fitment. The kit will be supplied with spacer plates that fit oem struts. If you have aftermarket struts, your own spacer plates may need to be made. Very simple piece of metal cut to size and of the right thickness for your application, with 2 holes drilled for the bottom strut bolts.
- You are on your own for making the exhaust line up with the new engine height.
- The engine and subframe will need to be removed. This isn't a small job and not for the faint of heart.
- I am NOT a certified welder in any way.
- This kit will not be sold as being road worthy or legal in any way. For off road use only.
- There will be no instructions with the kit. However, parts will be labeled and fasteners included. Most of the parts are self explanatory and you can always refer to the build thread for guidance. Plus I can be reached here by PM.
It wont be a $200 kit. It will be closer to the cost of other lift kits as there are some pieces that require custom water jet cuts and some parts that can only be acquired by buying an entire rear axle assembly.
So... anyone interested?
Old 04-22-2020, 01:39 PM   #213
ACKING_QC
Drives: 2018 VW TSi Stage1
any chances you're selling this kit but for an 05 Echo ? I have a little project in mind :P
ACKING_QC is offline   Reply With Quote
Old 05-13-2020, 12:24 PM   #214
myfirstyota
I've had no inquiries so I've shelved the idea. Sorry.
Old 06-08-2020, 03:02 PM   #215
Tskm2
Drives: Yaris hatchback 06
Its too much for me i'm looking more for 1.5 to 2in lift to keep my new tire from last summer
Tskm2 is offline   Reply With Quote
Finally bought a lift CTScott DIY / Maintenance / Service 26 09-28-2010 09:09 AM
zage turbo kit..! just need some help joseyaris Forced Induction Forum 12 10-29-2009 08:35 PM
Greddy xB kit vs Greddy Fit kit ellenbetty Forced Induction Forum 52 09-29-2009 08:42 PM
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast phu@xenon-vision Sponsors Classifieds Area 8 03-06-2009 02:33 PM
